The base brake's hydraulic system must be bled anytime air enters the hydraulic system. The ABS must always be bled anytime it is suspected that the HCU has ingested air.
Brake systems with ABS must be bled as two independent braking systems. The non-ABS portion of the brake system with ABS is to be bled the same as any non-ABS system.
The ABS portion of the brake system must be bled separately. Use the following procedure to properly bleed the brake hydraulic system including the ABS.
NOTE:During the brake bleeding procedure, be sure the brake fluid level remains close to the FULL level in the master cylinder fluid reservoir. Check the fluid level periodically during the bleeding procedure and add Mopar® DOT 3 brake fluid as required.
BLEEDING
When bleeding the ABS system, the following bleeding sequence must be followed to insure complete and adequate bleeding.
1.Make sure all hydraulic fluid lines are installed and properly torqued.
2.Connect the scan tool to the diagnostics connector. The diagnostic connector is located under the lower steering column cover to the left of the steering column.
3.Using the scan tool, check to make sure the ABM does not have any fault codes stored. If it does, clear them.
WARNING:When bleeding the brake system wear safety glasses. A clear bleed tube (1) must be attached to the bleeder screws and submerged in a clear container filled part way with clean brake fluid (2). Direct the flow of brake fluid away from yourself and the painted surfaces of the vehicle. Brake fluid at high pressure may come out of the bleeder screws when opened.
NOTE:Pressure bleeding is recommended to bleed the base brake system to ensure all air is removed from system. Manual bleeding may also be used, but additional time is needed to remove all air from system.
4.Bleed the base brake system. (Refer to 05 - Brakes - Standard Procedure)
5.Using the scan tool, select ECU VIEW, followed by ABS MISCELLANEOUS FUNCTIONS to access bleeding. Follow the instructions displayed. When finished, disconnect the scan tool and proceed.
6.Bleed the base brake system a second time. Check brake fluid level in the reservoir periodically to prevent emptying, causing air to enter the hydraulic system.
7.Fill the master cylinder fluid reservoir (1) to the MAX level.
8.Test drive the vehicle to be sure the brakes are operating correctly and that the brake pedal does not feel spongy.
Great job on the instructions Tom!!!I want to have my calipers powdered coated and knew i would have to bleed them.Now if i do them i will bring them in to have them blead, i was worried about the abs system?
I did mine at home. I didn't need to use the Predator to clear any codes either ....... nothing showed on the EVIC, and I had to bleed about a cup of air out of my brakes.
Pedal is firm, no issues with the ABS, and no codes.
I love it when a plan comes together.
Related Threads
Dodge Challenger Forum
1.7M posts
40.3K members
Since 2006
A forum community dedicated to all Dodge Challenger owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, Hemi Mopar power, power-adders, and more!
