When I start the car, everytime there is a kinda loud thump , sound like its coming from the rear of the car.
Is this normal, does not seem normal, have not had a recent car make this noise. It seems louder sometimes than others, Car has 300 miles on it, SXT V6. Any ideas or does this need to go back to dealer already ?
Thanks for any and all info. Flaps
What he said. I have had them say that too and the problem is there as soon as
I left. I had to explain to them how to recreate the problem and then they
fixed it in my ex Jeep.
Discussion Starter #4
Guess I will call them Monday and make an appointment. It happens with every startup, so they will easily be able to hear it. So I guess you guys are saying its not normal, my son thought it might be a noisy fuel pump start up or something common to the V6. Thanks for the input,, Flaps
Did you ever find the cause of the problem.........I have the same issue in my 19 GT. Happens 1 out of 10 starts, more often after I drive it and let it sit for 20 minutes then restart it. I've been under the car a number of times. There is nothing loose, drive shaft is not moving on startup, exhaust doesn't even move. Unable to duplicate. Dealer was also unable to duplicate the condition.
.....Thanks
Did you ever find the cause of the problem.........I have the same issue in my 19 GT. Happens 1 out of 10 starts, more often after I drive it and let it sit for 20 minutes then restart it. I've been under the car a number of times. There is nothing loose, drive shaft is not moving on startup, exhaust doesn't even move. Unable to duplicate. Dealer was also unable to duplicate the condition. It is now my mission in life to find the problem.....Thanks
Hi cujo221,Sorry to hear you are experiencing this concern, we certainly understand why this would be concerning. If you end up addressing this with your local Dodge dealer again, please let us know via PM. We'd be more than happy to provide you with an additional layer of assistance for that process.
Rob
DodgeCares
Rob
DodgeCares
Took it to the Dealer again same results. I will try another Dealership but could use some support. The Service writers listen to you but they don't "hear" or understand what your saying.
You forgot "...or care..." what you are saying
Hi cujo221, We'd be happy to help! Please follow up with me via DM at your earliest convenience so we can have this looked into further for you.
Rob
DodgeCares
So what can we do.
Hi cujo221, What we can do is escalate a case on your behalf so that one of our Case Specialists could work alongside your dealer to find a potential solution to the concerns you’re currently experiencing. Feel free to follow up with us via private message if this would be of interest.
Rob
DodgeCares
Rob
DodgeCares
Rob
DodgeCares
Have an appointment Monday Feb 24 at Flemington Dodge in NJ.
(Derek is the Service Advisor)
cujo221, I can not make you a case publicly because I require your private and personal information to do so. Please follow up with me in PM.
Rob
DodgeCares
Have the same issue. Going to Dealership for the 3rd time....will update the post if successful
