Hello!
I have a 2010 R/T w/ BBK shorty headers, 22s (no TPMS) and a muffler delete (the rest is stock). Shortly after I bought it (heavily used), the engine overheated and I replaced all the gaskets, intake manifold, and resurfaced the cylinder heads, which has fixed that problem. A "P0198 - Engine Oil Temperature Sensor Circuit High" code came on (the sensor is a thermistor whose resistance is inversely proportional to oil temp, the circuit has a 5V reference voltage), meaning (I think!) that the oil is either frozen (nope), or the circuit is likely open.
The code is permanent, so it's stored in the PCM and can only be cleared by the PCM itself, not any OBD2 devices.
I replaced the sensor, and drove it for about 250 miles, that did not fix it. I inspected the wires (including with a endoscope to check the hard to see spots), and did not see any wires that were exposed or worn, or any wire bundles whose cover was worn.
I replaced the wiring harness connector and tested the sensor/connector with a multimeter and got readings that fluctuated between about 30 - 175 ohms (Idk if fluctuating readings is normal or if my multimeter sucks, it's been a minute since my high school physics days) which I believe is a good reading for the EOT sensor at ambient temp.
Right now, I have to drive it some more to see if that will clear the code. I called a dealership and chatted with a tech (who was very kind to take my call and just talk!), and he couldn't give me any other advice besides taking it in and having them connect their witech and see what reading the PCM is getting for the EOT sensor circuit in real time, which is about $200.
While I'm putting another 200ish miles on this and keeping my fingers crossed, does anyone know how to get the drive cycles done faster, or how to get a EOT sensor circuit reading (at or near the PCM, as that would tell me if the issue is the wiring between the sensor and the PCM or at/in the PCM itself)? I've searched for a pinout (no luck), and already tried a few OBD2 scanners, including AlfaOBD which has the most accessible data that I could find, but it does not read the EOT sensor (don't think any consumer products do).
Thanks for reading this short novel, and TIA for any advice or help!
