now that tax time is over and Uncle Sam has graciously refunded some of my money, i am planning a few underhood mods and would like some input from members who have already done them... i just want to be sure i have all the parts, knowledge, tips & tricks on hand so the build goes as smoothly as possibly...
i had a consultation with Tim at Modular Power House in Rockford Illinois (formerly Mr. Norms) and they will be doing the work... i felt the meeting went very well and feel comfortable and confident i will get the results i am looking for... from the conversation with Tim, he seemed to think that the car would be in the 525-540 rwhp range... :SHOCKED:
as always, after the fact, you always come up with additional questions that you forgot to ask so i wanted to present them to the forum as i know many of the members have already done these mods...
1) 6.1 exhaust manifold swap
Tim said he could probably get ahold of of a near new set of manifolds and mids so hopefully that works out...
A. do i need to order new exhaust manifold bolts? i'm thinking i do but just want to confirm...
B. i think i read on the forum that the factory 6.1 exhaust manifold gaskets are better quality than most aftermarket gaskets... is that true?
C. i read on the forum that the R/T oil dipstick may be different than the 6.1 oil dipstick and may need to be bent or modified so as not to rub or rest on the manifolds... any truth to that? should i order a 6.1 oil dipstick or would i just be wasting money?
D. what size is the 6.1 midpipes? i'm thinking they will have to be reduced in order to fit my Corsa Extreme on my R/T
2) i am planning on doing the 6.4 auto cam swap into my 5.7 auto R/T... in addition to the factory cam, what other pieces or parts should i do... like valve springs, push rods, things like this? can anyone suggest any manufactures or maybe just order through dodge?
3) i am planning on upgrading my 6lb factory supplied magnuson S/C pulley for a 3.10 diameter 8lb pulley... so far i have only come across one vendor located in southern florida that sells them... does anyone know of any other supplier or vendor that may carry them?
***also while the car is being worked on, i am planning on having them do the timing chain recall work... that is actually what has gotten this ball rolling is the recall... i figure if someone has to open up the front of the engine, might as well do a cam swap too...
thanks for taking the time to read all this and hopefully we'll all get a little something out of it... :4-wavey:
