Yes I know , but I,m wondering if there is a rubber bump stop on the rod/shaft of the shock up under the sleeve ? Theres a sleeve on the upper portion of the shock . You,ld have to take the shock off probley to tell . I was hoping someone might have a factory shock laying around so they could check . Thanks . BooBooThe standard rear shocks and springs are separate mate.
Apologies, I misunderstood the question. I don't think there is one under the sleeve, but I'm not 100% sure.Yes I know , but I,m wondering if there is a rubber bump stop on the rod/shaft of the shock up under the sleeve ? Theres a sleeve on the upper portion of the shock . You,ld have to take the shock off probley to tell . I was hoping someone might have a factory shock laying around so they could check . Thanks . BooBoo
