1 - 5 of 5 Posts
2009 Challenger R/T Auto
I've got 10's on mine. It really depends if you're lowered and rim offset. Once you get beyond a certain point, you'll need to have the wheel wells rolled to make things fit and not hit.
No, 275/40-20's. If you get much wider you'll have to go with a different offset on the rim. Mine is 18mm. There's a lot of members here with wider tires that may be able to give you what they are running and if they had to roll the wells.
I'm running a 20x10 +25 on all four corners
285/35/20 front
315/35/20 rear
Lowered on Eibach prokit springs
5mm hubcentric spacer in front for the tire to clear the steering knuckle
rolled fenders and some trimming of the fender liner in the rear
Still an occasional rub on big bumps and hard cornering, no damage just noise
1 - 5 of 5 Posts
