I bought a 2014 Challenger SXT Plus. It had stock headlamps that I wanted to upgrade to HID. I took it to a fairly reputable installer recommended by the dealer to upgrade to HID.
My issue is that the low beam looks like high beam and vice versa. When I switch to high beam I just see the ground in front of me. With the low beam I see all the signs ahead of me on the road light up brighter. There is no focus on the ground in front of me with the low beams.
Now I'm not too sure how they did the conversion. Does anyone know if any wire splicing would have had to be involved? They used the H13 bulb and told me it's the same bulb for high/low beam, it just 'moves' when you switch to brights to get repositioned. I'm thinking if any splicing was involved they may have wired it backwards.
When I'm looking at the headlamp directly, on low beam it appears to be coming from the 'bottom' of the headlamp and on high beam it appears to come from the 'top'. When I focus the beam on a garage door or wall at dusk, it looks like the high beam focal point is a few inches lower than the low beam focal point (brightest point of the beam). Anyone else with HIDs have the same effect as me?
Also, anyone with stock HIDs, do you know if the headlamp assembly is different to accommodate the stock HID bulbs and project the light differently? I'm thinking it's possible this may be my problem as well (if it's not a wiring issue).
