21 - 40 of 61 Posts
Discussion Starter · #22 ·
Based off the 351 Windsor Block... What do you see
???? I'm a lil confused by your post. What's a 351 Windsor have to do with anything?
A 345 taken to a 393 with Supercharger is not likely going to hold up very long be prepared for lots of issues. It's your dime and good luck.
Go ahead. Ask me how I know a 392 stroker is a great build...
Reactions: SweetT
Discussion Starter · #35 ·
Which crank? Who’s combo is it? Why they go 8:1? Just curious
Callies 4.080 8 counterweight. They have a 4.050 8 counterweight off the shelf. Custom pistons
8:1 compression lets you run more boost. With them same octane. Low CR higher boost makes more power than higher CR low boost/ high CR NA engines.
1 CR = 2% HP increase avg.
1 psi = 16-20hp avg.
1psi boost requires 1.5 octane
1 point CR requires 3-5 octane
2016 Dodge Challenger
Don’t those 8 counter weight cranks come with a key way???
The one I saw did
Ethanol is forgiving. Pump gas not so much. Run ethanol and 10.5:1 compression and you won’t have to max out the blower to achieve your desired hp level. Spinning the blower harder causes heat and it’s own set of problems
21 - 40 of 61 Posts
