1 - 20 of 81 Posts
I did mine at 30000 miles too and they looked fairly good and could have easily gone another 8000-10000 more miles.
Mine too. But the change did gie a smoother, more responsive throttle response.
Average Guy
I just hit 30K this week also and wondering the same thing. I still have on the original Firestone tires, they look like another 5 or 6K and they'll need to be replaced.
So it sounds like 35 - 40K would be a good point to change out the plugs?
Any opinion on plugs (at a reasonabl price)?
30K and not a single problem (other than the rocker panels), the car runs great! :smileup:
On my wifes 300C I changed them several years ago at 50,000 miles and they looked pretty good. Couldn't really tell any difference after the change.
30K and not a single problem (other than the side rails), the car runs great! :smileup:
For a car that's mainly stock I'd stick with OEM recommended plug NGK #LZFR5C-11.
I got my last set off of eBay. They were cheaper than the dealership. Make sure you use anti-sieze on the threads and di-electric grease in the boots. Factory specs call for a .043 gap, I gapped mine at a tight .045
Also, save yourself a little time during the install. Gap and anti-sieze before.
These were mine at 30000 miles.
They only put 6 plugs in your 8 cylinder R/T?
I had mine replaced at like 50k. They were a little worn. I think it runs better.
My only concern with not changing them out at 30 k is what impact it could have on the power train warranty.I don't want to give Dodge any excuses.
Good point Art, I guess not changing them would be giving dealer ammunition that they could use against you if there is a problem.
Dazed & Confused
I did mine at 28k, they looked good. I would have no problem stretching them a little further than what the manual says.
Totally worth it, changed mine 29500 and they looked pretty good, however the gaps were all wrong and there was some build up on them. After I replaced them I noticed better throttle response and the early morning second gear lurching out of my neighborhood stopped. It accelerates much smoother now just overall happier.
I haven't changed my but I will do them after the winter season my car is at 48K now.
Average Guy
Thanks Bad8nti, appreciate the guidance!
I couldn't find a cheap set of 16 on ebay, but did find a Chrysler OEM parts site that has them for $4 each. My dealer wants $8 so that's a savings of $64 on a change.
http://chrysler-partscenter.com/par...=SPLZFR5C11&action=oePartSearch&siteid=217025
I did mine at a little over 40k and the engine still ran good but MPG's had fallen off some and once I changed them I could immediately tell the difference. I will change them out at 30k intervals from now on, it gets better MPG's and is WAY smoother.
1 - 20 of 81 Posts
