I really did not consider going to a one piece driveshaft to be a performance upgrade until I swapped out the OEM two piece driveshaft for a DSS (The Driveshaft Shop) one piece 4" Aluminum driveshaft, but after a few days of driving and every time I drive now, I discover something different in the performance realm.
The engine output to rear end response is pretty much instantaneous now, and the resistance of an extra CV joint and carrier bearing is gone, so there is less drive line resistance being applied to the operation of the drive line. The car does not respond like it did before the change, it is like a completely different car, you would have had to drive before and after the change to fully understand, but there is a noticeable difference.
There is more unrestricted power reaching the rear end, which translates to more tire spin, which of course adds to the dilemma of getting off the line with a good launch, but that consequence is most welcomed to me. But the fact that suddenly increasing throttle in 3rd gear and not to the floor, got tire spin put a smile across my face, that had never happened in the past.
When I went from an open differential to a limited slip, I got the smile from both tires laying down solid rubber. When I added the 93 octane tune written by Sean at Hemifever Tuning I got the smile as well. But I honestly was not expecting the smile going from the OEM 2 piece driveshaft assembly to a one piece Aluminum, but the smile is there!
What led to me getting the one piece driveshaft was the carrier bearing failure that led to replacing the OEM two piece assembly, but IMO, because of the cost did not warrant getting a single driveshaft of 1,000+HP rated on a 5.7L HEMI, that cost me a little over a thousand dollars. Unfortunately after the carrier bearing failure I could not get completely comfortable running the two piece OEM anymore, as the mental picture of the failure was permanently burned into my mind. So I made the decision to go to the one piece driveshaft, but did not need the Carbon Fiber on an engine probably at 400HP now, so a 1,000HP rated driveshaft is way overkill.
FYI: Any of you not aware of the carrier bearing failure here is the link to it: Replacing My Drive Shaft! WARNING!
Increased performance was a really good side effect when all I was really after was peace of mind, and increased confidence in the car! Only those that are actually running the single driveshaft in their Challengers, whether Aluminum or Carbon Fiber, can co-confirm any differences they have noticed, so I invite them to add their 2 cents in this thread.
Thanks and be Safe everyone!
Ry
