6.1 stroker build for my 2010 R/T
Discussion in 'Challenger Performance Mods - Engine - 6.1L HEMI' started by chizzle1, Oct 12, 2017.
  1. Mopar forever
    Mopar forever Active Member
    Jul 19, 2016
    1,195
    1,508
    Gender:
    Male
    Bostic n.c.
    Vehicle?:
    challenger
    Trim?:
    R/T Scat Pack
    Color?:
    Sublime
    Transmission?:
    8-Speed Auto
    Ol man that thing is nasty but won't be for long huh ;)
    chizzle1 likes this.
  2. jklotz10
    jklotz10 Well-Known Member Member Relations MOTM Winner!
    Jan 26, 2011
    9,620
    Media:
    73
    Albums:
    5
    4,008
    Kewaskum, WI
    Vehicle?:
    2010 CHALLENGER
    Trim?:
    R/T Classic
    Color?:
    Plum Crazy
    Transmission?:
    Auto
    Could you use a grease pencil to trace around the hinge where it mates with the hood?
    At least you could wipe the mark away when your re-installed.
  3. chizzle1
    chizzle1 Active Member Military
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    i just picked up another set of bits from lowes this evening, hoping to have it cleaner looking by the weekend...work and wife permitting :)
    I wish I had time to test the stock vs ported intake, i think with the cam and larger displacement the port work will be well worth it. I'll need to gasket match the eagle heads for the larger 6.1 intake ports before final assembly.
    good idea, i was thinking sharpie but the grease would be much easier to clean off. thanks.
  4. wvhemis
    Apr 24, 2014
    9,104
    Media:
    1
    Albums:
    1
    8,766
    Gender:
    Male
    Charleston, WV
    Vehicle?:
    Challenger
    Trim?:
    R/T Shaker Edition
    Color?:
    Plum Crazy
    Transmission?:
    Auto
    Sounds like you are making nice progress. Are you going to get the manifold bench flowed after your porting?
  5. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    nah, just install it and go. I don't know a local place that will do that and I don't have the funds if it's expensive.
  6. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    update: ordered a mopar damper, the aftermarket one was garbage....
    Also ordered a replacement oil squirter assembly and replacement crank bolt.
    Steve white motors is awesome, got a great deal and free shipping.
    After read a LARGE amount of information on the oil squirters, I have decided to keep mine in place.
    The 405 crank should allow the pistons to clear, if not I'll adjust fire, but the benefits of the squirters spraying oil on the back side of the pistons at high rpms is worth the effort in my opinion.
    once the damper arrives I'll have the keyway machined into it and be good to go.
    here's the part number if anyone else needs it:
    https://www.stevewhiteparts.com/oem-parts/mopar-jet-piston-oil-cooler-5037524ab
  7. Mopar forever
    Jul 19, 2016
    1,195
    1,508
    Gender:
    Male
    Bostic n.c.
    Vehicle?:
    challenger
    Trim?:
    R/T Scat Pack
    Color?:
    Sublime
    Transmission?:
    8-Speed Auto
    I love to drive up to Steve whites and look at what they are building. It only about 35 min from my house
    wvhemis and chizzle1 like this.
  8. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    currently debating on swapping from SRT8 shorties to long tubes...not sure if they are worth the $800-$1000 as the shorties seem to flow pretty good.
  9. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    block boring & honing is completed, going to drop off the reluctor wheel and look into maybe going red with the block. the 2006 factory block paint is pretty much done, and I want to match it with the color scheme on the car already. Wire brush it, shoot it with some self-etching primer and red engine block paint.
    If I didn't mention it before: make sure the wheel you install matches what PCM you are using.
    All 09 and later 5.7/6.1 use the same wheel. Pre-09 6.1s and 5.7 used different wheel attachment points and different tooth counts.
    jklotz10 likes this.
  10. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    Next hurdle...valve spring debacle.
    So after speaking with PAC the fix for the 1235 springs working with the .625 lift on the big cam is setting the install height to 1.850, or swapping to 1211X springs and larger retainers.
  11. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    UPDATE: Displacement changed to 426 due to non-availability of 3.90 crank.
    K1 has discontinued the 3.90 crank, so they sent us a 426 (4.080) crank and rod kit...this was discovered when the machine shop was balancing the crank and got a good look at the model numbers.
    Not a big deal, 20 cubic inches more displacement and a slightly larger cam profile.
    The piston squirters, crank bolt, and other misc parts I ordered from steve white won't be in until next week so build will be on pause.
    We are looking at upgrading to LS double spring style valve springs as they are much more affordable than similar setups from companies / vendors I won't mention here.
    Once I get the heads off that will be hammered out for sure, but right now it's looking like double springs will handle the .625 lift better than the beehives I previously installed.
    more to follow...
    wvhemis and jklotz10 like this.
  12. jklotz10
    Jan 26, 2011
    9,620
    Media:
    73
    Albums:
    5
    4,008
    Kewaskum, WI
    Vehicle?:
    2010 CHALLENGER
    Trim?:
    R/T Classic
    Color?:
    Plum Crazy
    Transmission?:
    Auto
    A 426 HEMI in a MOPAR.......has a nice ring to it............
  13. wvhemis
    Apr 24, 2014
    9,104
    Media:
    1
    Albums:
    1
    8,766
    Gender:
    Male
    Charleston, WV
    Vehicle?:
    Challenger
    Trim?:
    R/T Shaker Edition
    Color?:
    Plum Crazy
    Transmission?:
    Auto
    You will need some nice custom 426 HEMI badges now !
  14. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    thanks, i was kinda miffed at first but I am ok with it now.
    I was thinking the same thing. I am going to try and find a place to make a custom fender badge with the scat pack bee and '426' under it.
  15. wvhemis
    Apr 24, 2014
    9,104
    Media:
    1
    Albums:
    1
    8,766
    Gender:
    Male
    Charleston, WV
    Vehicle?:
    Challenger
    Trim?:
    R/T Shaker Edition
    Color?:
    Plum Crazy
    Transmission?:
    Auto
    I was thinking 426 Hemi to go on your shaker. That is just so old school.
    jklotz10 and chizzle1 like this.
  16. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    update: ordered melling high volume pump and mopar water pump from Rockauto, I'll need to google how to swap in the high pressure spring required when running the piston squirters.
    Summit has the oil pump pickup tube for $20, the dipstick & tube are $17 from rockauto...the little parts are starting to add up.
  17. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    need some help: what size and thread type are the 6.1 intake bolts?
    I'm not paying dodge $10 each when I can get a better grade bolt from fastnal for half the price.
  18. jklotz10
    Jan 26, 2011
    9,620
    Media:
    73
    Albums:
    5
    4,008
    Kewaskum, WI
    Vehicle?:
    2010 CHALLENGER
    Trim?:
    R/T Classic
    Color?:
    Plum Crazy
    Transmission?:
    Auto
    The bolts that connect the intake manifold to the heads are M6x1.00x35.00 P/N 06509098AA
    Qty 10 req'd
  19. chizzle1
    Jan 6, 2010
    2,401
    Media:
    14
    Albums:
    3
    373
    Texas
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    Brilliant Black
    Transmission?:
    6-Speed
    thanks, I'll head to fastnal and order them grade 8. definitely cheaper than $75
Share This Page
