I really think you dont need anything now Jim, I have a 3.2 pulley on mine now which is giving me 8 lbs boost and im not having any problems.Now, I'm just wondering, see...just wondering. :i_rolleyes:
Other than the pulley swap, what other work would need to be done to go up to #8 from #6 on the 5.7L? Fuel pump? Injectors?
Remember, I'm just curious![]()
I definitely want to look into the gauges for sure. Need to do a search and see if anyone's added them and done a write-up on it. I guess I'm gonna go for the Speedlogix mount that replaces the sunglass holder because I don't want them anywhere near the airbags on the A-pillar.I really think you dont need anything now Jim, I have a 3.2 pulley on mine now which is giving me 8 lbs boost and im not having any problems. That being said an Arrington fuel pump wouldn't be a bad idea, its cheap insurance, and a few other things like A/F & Boost gages. If you go over 8 lbs then i would say you definitely go for the fuel pump and injectors...
Gonna look up his thread, think I remember seeing it before. Thanks for the post, Alan....and a few other things like 345 Chlngr did, He definitely went first class with his build.
Was just on Arrington's page looking at things. Are the 50lb injectors suitable for 8 pounds of boost? I was thinking going to 8 pounds would put me over 500hp. Not sure on that, though.Your Maggie Set-up should have came with 50lb Injectors.
Wondering if I could handle the fuel pump install myself. Though...I am about a 4hr drive from Arrington and could always make a trip of it and let them dial in the tune at the same time.The API Competition Fuel Pump should be installed IMO just to be safe. Obviously you need the 3.2" Pulley for 8lbs of Boost, it will probably be more than that with Cold air under 40 degrees.
Any info on the wideband and boost gauges? Think it was a Jegs catalog I was looking in the other night and they had a myriad of gauges that confused me more than anything else.If you don't have a Wideband Gauge than get one before you start upping the Boost. A Boost Gauge is nice too especially to help you stay out of Part Throttle Boost scenarios.
Hehe...can't say that wouldn't be awesome. In my head right now, I feel like once I break 500hp, I'll be content for a while.I warn you though once you start going here you will want more, look how long it took you to go from 6 to wanting more. Just be ready to pay out for a Forged Motor once you start down this road.
Off to read! Thanks :smileup:Don't forget the most important part Tune that Bad Boy.
http://www.challengerforumz.com/showthread.php?t=94873
I'm putting my pump in this weekend. It comes with very thorough directions just like the Super charger did. Seems pretty straight forward. With the forum and a couple "help hot lines" haha I think I will get it done.Was just on Arrington's page looking at things. Are the 50lb injectors suitable for 8 pounds of boost? I was thinking going to 8 pounds would put me over 500hp. Not sure on that, though.
I get a little nervous working around fuel tanks...especially when there's wiring to do (yeah, even if the battery is disconnected; have had a few battery experiences that were not all that pleasant)I'm putting my pump in this weekend. It comes with very thorough directions just like the Super charger did. Seems pretty straight forward. With the forum and a couple "help hot lines" haha I think I will get it done.
PM Me if you have any questions on anything... ThanksWas just on Arrington's page looking at things. Are the 50lb injectors suitable for 8 pounds of boost? I was thinking going to 8 pounds would put me over 500hp. Not sure on that, though.
50lb injectors are good to 500HP with the right fuel pump.
Fuel Pump install is easy, just have fuel tank under 1/8 tank of fuel.
I would do the pillar gauges, best place to see them. Airbag does not interfere with them.
Can't recall from your install thread, did you get a custom dyno tune w/ the install? If not, I'd do that before upgrading to 8lbs. Also, when I bought mine, I asked Arrington about the 8lb kit. I only have 91 oct here and was advised I would need a minimum of 93, so I went with the 6lb kit. Plan to stop by Arrington next year when I'm in that area to get a tune done by them.Now, I'm just wondering, see...just wondering. :i_rolleyes:
Please share so I know what to look out for. I'm well aware of working withI get a little nervous working around fuel tanks...especially when there's wiring to do (yeah, even if the battery is disconnected; have had a few battery experiences that were not all that pleasant)![]()
Thanks Stewart!PM Me if you have any questions on anything... Thanks
Arrington did the tune as far as the car specs sheet sent to them and then they sent the tune file to the installer for uploading to the ECU. I've not had the car where they can test/tune it in person.Can't recall from your install thread, did you get a custom dyno tune w/ the install? If not, I'd do that before upgrading to 8lbs.
That's interesting...I'd have to go back to using E10 gas as my local puregas guy only goes up to 91.5Also, when I bought mine, I asked Arrington about the 8lb kit. I only have 91 oct here and was advised I would need a minimum of 93, so I went with the 6lb kit. Plan to stop by Arrington next year when I'm in that area to get a tune done by them.
Not much to say really...I was just referring to an errant spark setting off gas fumes. I looked at the install doc and you do open the tank up (probably why they recommend the tank be close to empty). I've had a couple issues with shorted batteries. Once at work when a coworker shorted across a wet cell battery with a ratchet (big boom, flames and a mushroom cloud rolled past me as I was on a ladder next to the guy). The other time was when I was a teenager, wiring up a snow plow on a dump truck. Carelessness, the culprit. The top of the battery flew past my head and stuck in the roof. So, since those two incidents, I'm real slow and steady around batteries, yet still paranoidPlease share so I know what to look out for. I'm well aware of working with
Yeah, it kinda sucks. Guess I should have planned better. Mighta gotten the Cervini's and had no Shaker issues after the s/c went on. Ah well. I still like the AFR better, just need to get it redesigned to work. Was gonna swap hoods this weekend but never got motivated enough to do it. And now the temps have dropped quite a bit again with maybe a little bit of snow on Tuesday. So I guess I'm gonna drive it back to the storage area tomorrow. This coming weekend is looking warmer though so I'm sure I'll take tit out again. It's a dang rollercoaster. Need the Spring to get here and stay here!Separate note wish I lived closer love to get that shaker back on.
Hah! That's pretty good!saw this on Facebook LOL
