I test drove a 22 scat pack with 4,500 miles on it and the manual 6 speed. It did not like cruising at lower rpm's (1500-2000). On the interstate at about 65 mph, it would stumble in 6th gear and I had to use 5th to get it to smooth out. Even around town I had to use lower gears than should be required to keep it going. My 2012 Challenger would cruise smoothly in that rpm range and I have had several other 6 speed cars that had no problems. Is this normal in the newer cars?
Also, the dealer had let the battery die and the car had to be jump started. After that, the check engine light was on. Could this be the cause of the issue? Do these cars have a "limp mode" they go into when there is a problem?
