WeLLLLLL... now I went and did it! I was installing my Hurst shifter and when I went to tighten the "shoulder bolt" [I think that's what its called I snapped off the threaded part in the OEM rod that the Hurst shifter attaches too. Now I'm guessing I can try and drill out the threaded piece I snapped off but If not does anyone know where I can buy the rod and the 2 shoulder bolts? I'm guessing this may be a dealer only item but thought I'd check here first. BTW - I did use a torque wrench and had it set to 15lbs... apparently I don't know what 15lbs should feel like and I over torqued the blot snapping it off.
