1 - 8 of 8 Posts
2010 RT with 6 manual transmission. . What Trans fluid do you guys recommend? I've read some like royal purple synchromesh and amsoil synthetic. Any preferences and did it actually smooth out the Trans. Sometimes I noticed mine is hesitant to go into gear.
I have been happy with the RP Synchromesh. Make sure you get the pump kit to add the new fluid.
Mine seems a little less notchy then with the stock ATF. Specially between 1-2.
Change the rear diff fluid also. I changed mine at 25k and it was nasty.
RP makes gear oil with the friction modified for the limited slip blended in, and it will dissapate heat better than the stock gear oil.
Reactions: Lyle
How many quarts does the limited slip rear end take?
I completely emptied 1 bottle, and most of the second. I think it's just under 2 quarts.
I over filled it slightly to allow for fluid to work it's way into the LSD assembly.
1 - 8 of 8 Posts
