Yep, roger that! I would think there is some kind of warranty but I know there is nothing from Chrysler.No warranty from Chrysler that I'm aware of. Depends if there is a warranty from the Petty's install or not.
They told me 8 pounds was safe.They recommend 6 psi. ( after 8 psi stared poppin pistons)
I've noticed a lot of vendors have dialed things back to 6 pounds in their adds now that there has been a number of failures at 8 lbs and greater.They told me 8 pounds was safe.
Do you have it in writing ... along with a warranty statement from Petty? I hope they do the right thing by you.They told me 8 pounds was safe.
Great post John!!:smileup: That 8 thousands or pretty close to 1 hundredth thinner is still a problem IMO along with any funny business that might be going on with the silicon % mix. We need to bare in mind that these Hemi pistons ALL are VERY close on that top ring land to start with and ANY further less like the 392's are just that much less safety zone for blown applications. I think this may have something to do with why that part throttle tune is giving the 392's more problems than the 5.7's in a same year model using the newer encrypted PCM's. I recently saw a picture of a stock 392 piston next to someones aftermarket piston....I forget where this was shown....and all I will say is...there was a VERY visible difference in the amount of metal above that top ring land!!From what I remember, Arrington Engines found out that some tunes are the problem. Issues arise when the fuel goes lean during part throttle boost.
A quote from Alex at Arrington in this thread http://www.challengerforumz.com/showthread.php?t=93721
Post #61 to be exact.
"We have come a long ways tuning the 392's. After doing A LOT of research to find out why pistons were burning up we figured out it wasn't the pistons fault. Even though they are about .008 thinner on the top ring land than a 5.7 or 6.1 they can still take the boost as long as they don't run out of fuel. Part throttle tuning has made leaps and bounds over what it used to be, especially with the new software we are able to flash these boxes with, making these pistons happier longer. You will still see a low 11 A/F at WOT because that isn't where they were running into issues and breaking. It is the transition into boost at part throttle creating the lean issue. Some software just doesn't have the ability to cover that area. Leaving a lot of 392's needing a piston upgrade."
:3-smoke:
Alan - so Josh is now safely running 12lbs on 5.7s? I thought 8lbs was all he was comfortable with? - I love to hear the progression!Agreed Dan, something is definitely going on with those 392 pistons, when I saw Josh at HHP earlier this week he said a lot of his customers go up to 12 lbs boost on the
5.7 without any problems and he said not to worry about the pistons as long as the tune is good, from what I've seen there is no way the 6.2 pistons could handle that.
Yeah, that really surprised me when he said that, Its kind of putting nuttey ideas in my head.:revenant:Alan - so Josh is now safely running 12lbs on 5.7s? I thought 8lbs was all he was comfortable with? - I love to hear the progression!
This is very true...most of them however usually involve thinking we can do something we used to when we where younger....LOL:hah:Well when we get older, we do get a lot of nutty ideas!!!
