1 - 4 of 4 Posts
Hi guys,
I'm trying to figure out how to fix the mold smell that my car has when I turn it on. I think this is common in texas given that we use the AC mostly year round.
One thing I noticed is that my wife's honda accord drips a lot of condensation, specially after she parks the car leaves a puddle of water. My car drips nothing or very little, so I'm wondering if my AC drain is clogged.
I tried to find the drain with no luck as per pictures I found online. Based on a couple of drops I found it seems its coming from over the tranny a little bit to the drivers side, but I cant see nothing.
Can someone explain in detail how to locate the drain (3.6L 2013)?
Also I found a tube drain coming out of the belly pan on the passenger side (picture attached), but I'm not sure its that based on what I found online.
Thanks for the help!!!
Yes, that is what I thought based on where I saw some dripping but got under the car and saw nothing... should I access it from under the car or from the top of the engine?
Maybe if someone has more specifics?
Unless they moved it and I doubt it, it is over the transmission and on my 09 the condensate just runs down over the transmission drips off it where ever it decides to, mostly on the passenger side.
1 - 4 of 4 Posts
