Search results for query: engine swap se
This is where you can research this ... Best you can do more sensible is to go 1 of 2 ways.
1. Use your car as a trade in unless you want to dump easily over 15k to remotely get it right because you need a DONOR CAR that has been wrecked to have
all pieces for the swap....
2. Find hard to find Supercharger , PCM, Trans Upgrade etc. ,and enjoy the V6.
Your not the first to ask and the issue is it is not an easy task and no one makes a swap kit with instructions. That is behing Honest and Straight Forward.
When you take a NON HEMI car like yours that means its not meant to have one because it does not have the Cross Members. Harness, etc., for a HEMI...
That means no one here can tell you a step by step how to do such a project with everything being perfect.
It's going to bring headaches, and things modified like that is more prone to break and not work smoothly. That is why most say trade up that is the best
sensible and easiest why to get a Hemi Challenger. As an ASE MECHANIC and former ASE BODY / PAINT CHASSIS guy and one whos built Hotrods,
Race cars its not a easy swap and no one makes a Guide and gives you all the parts to embark on this project. It's trial , Error, Patience, and Money.
Above is a link on tons of others asking and read the threads on here and many with same backgrounds say it straight out being honesty why its not
a sensible project unless you got a HEMI Donor mainly a Wrecked Challenger...
Finally people have done it but many not successfully regardless what a Youtube video may say. Why dont they list the parts and instructions?
You can do some HP mods and get more out of that 3.5 but its a more limited option to do so then say a later SXT with the updated
3.6L Pentastar Engine with upgraded parts form Fiat Chrysler which already boost 50hp more with a true dual exhaust.
They have Throttle Bodies, Exhaust, Trans Kits and Suspension to help a V6 work better. No one Shut you down but if you wan to really do this
there is other things you need to consider. Many States wont allow that to be done for resale that's right in some states your not legally able to
do anything with the car like this and pass inspection based on the VIN, Insurance wont cover a wreck mod recouping that mod, most wont touch
a car like that being modded because they are leery is it done right how reliable, was all mods 100% done and properly.
Your Suspension wont hand the weight difference, the Cross Member Cradle is different the Chassis is different in some places, as well.
Beyond that if you want to do it and your determined and have the money time etc., Ok Build your Dream and be proud of it.
