Another alignment thread
198 views 10 replies 4 participants last post by  JustWannaSpeed
#1 ·
I am going to a night class for Automotive and took my car in for alignment just to see and this is what I got back. I searched and read alot of threads about corrective bushings, adjustable upper control arms,front camber bolt,rear camber kit.,etc. Little confused about what I actually need to straighten out alignment on car. My tires are starting to wear in front alittle. If you completed this what parts are good quality and will it solve the issue? Thanks!
#2 ·
Press in bushings can be used in the rear but their maximum correction is 1.5 degrees, now if the rear is out no further than negative 2.0 degrees then a 1.5 degree correction leaves .5 of negative camber and that is good. Any further out like 3 degrees in the negative you'll need fully adjustable upper control arms.
To correct the front you'll need a fully adjustable upper A arm.
#7 ·
The right and left front negative camber on my 2023 Dodge Challenger RT T/A are equal to one another; both are at -1.5 camber. Check out the attachment below...
#9 ·
You might look underneath at your springs... if original MOPAR sprimgs, they usually have a label attached with a part number. I would check to make sure the part numbers match. Then I would check the shocks to make sure one hasn't failed. It's odd because the camber is not adjustable with factory components.
Reactions: ljb2148
