1 - 9 of 9 Posts
Has anyone converted to a Hurst shifter with white or blk ball using Oem factory plate. Only arm and ball not removing anything else.
If so, how does it work when installed? Does the larger rectangular size affect shifting or how it sits into the different gates?
For 14' AT
Thanks
Discussion Starter #4
right on, thanks.
im guessing best is to position the new shift portion just above the oem gate trim so as to not rub.
Discussion Starter #6
hey jackal, would you mind sharing a few pics of the installed product. i would like to see how it looks with the space between the original stick and the space above the gate area. thanks!
1 - 9 of 9 Posts
