1 - 1 of 1 Posts
2020 Challenger R/T Scat Pack
Has anyone added a HellCat Oil Cooler or the Mishimoto oil cooler (w/thermostat) to their 6.4L?
I was thinking if a HC cooler was used it could be a bolt on and you might be able to leave the small stock OE oil/water cooler on the engine. Unscrew the filter, screw on the aux. cooler adapter plate then reinstall the filter.
Mishimoto makes a replaceable thermostat for the oil cooler as well. They have 3 thermostats, 160, 180 and 200 degree. It would keep everything operating OE until the oil temp reaches the thermostat setting and then it would allow flow thru the HC cooler.
Just curious if anyone has tried this.
1 - 1 of 1 Posts
