@Mopar_NoCar
Looks like in your picture you plugged off the PCV airbox line and if you did that did you also plug off the air tube on the oil fill neck and install the air filter top in place of the factory oil fill cap?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjYyKfU9vT9AhV5LkQIHbx9CpkQFnoECA8QAQ&url=https://treperformance.com/pdf/327327&usg=AOvVaw0hiGv3ts9Ki7nBxqsopl9K
I read over your Whipple installation instructions this morning the link above is the PDF of the Whipple instructions.
Before I tell you what you have done wrong I would like to say that I am impressed with some of the supplied hardware of the Whipple vs the Magnuson. I really like the reservoir setup the Whipple comes with. I also like that Whipple supplied pre-bent metal pipes with rubber O rings to duplicate the stock 5.7 heater core connections to the water pump, that is very nice.
This is what you have wrong and I suggest you immediately fix it, you clearly have a filter Top on your oil fill port.
Whipple Installation Page 68 item #206 Reuse Factory Oil Fill Cap In Oil Fill Neck.
Why would Whipple want that sealed with the factory cap that has a rubber O ring in it to completely seal the top so no air could get in through the top. If they wanted a filtered top there they would have supplied one for you to use, but they did not. Because their next instructions are about reconnecting the fresh air line to the stock air box connection point.
Why would they want that PCV fresh air line reconnected? Because it serves 2 purposes, it supplies fresh air to the crankcase at all times especially when the PCV valve is open and flowing. It also supplies a constant vacuum to the crankcase keeping a slight negative pressure on the crankcase at all times, especially when the PCV valve is closed.
Whipple Installation Page 69 Items #210, 211, 212, 213, If you have done anything different from these instructions, Please, correct it, no matter what you think of me, I do not want you to hurt your engine and with the Whipple supercharger you have the power to do it. So cuss me if you want, it won't be the first time, trust me, but Please fix it, if anything is different from the instructions.
Possibly some of the problems you have been experiencing are related to or because of that, because you do not have the supercharger connected as Whipple instructed you to do. Ry
EDIT: Whatever you do, never show that above picture to Whipple, I guarantee you, it will void your warranty.
