1. ann10
    ann10 New Member
    Nov 11, 2017
    5
    2
    Gender:
    Female
    Texas
    Vehicle?:
    RT CHALLENGER
    Model Year?:
    2010
    Trim?:
    Mopar 10
    Color?:
    Dark Titanium
    Transmission?:
    8-Speed Auto
    Both of my blinkers blink really fast like if a light bulbs out but I’ve checked all of the lights and they’re all working. What could it be?
  2. Dodgeguy
    Dodgeguy Highway Star Member Relations Photo Winner! MOTM Winner! Public Safety
    Jul 11, 2010
    28,320
    Media:
    69
    Albums:
    5
    35,722
    Gender:
    Male
    Tucson
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T
    Color?:
    HEMI Orange
    Transmission?:
    6-Speed
    Well you checked what I would think it would be. Somebody may have an answer.
  3. TheOldGuy
    TheOldGuy Will Fabricate Anything For Space Shuttle Ride Site Supporter Level 3 MOTM Winner!
    Oct 22, 2013
    1,790
    Media:
    19
    Albums:
    2
    3,104
    Gender:
    Male
    Right Here, Right in the Beautiful State of Maine
    Vehicle?:
    Challenger 2016
    Trim?:
    R/T Scat Pack
    Color?:
    Ivory Tri-Coat Pearl
    Transmission?:
    6-Speed
    Look at the tail-lamps while the blinker is on. See if the tail-lamps are alternate flashing with the brake light lamps. In other words, alternating between dim and bright. Then come back here. I'll tell you how to fix it.
    69SatelliteSport likes this.
  4. 69SatelliteSport
    69SatelliteSport Member
    Jun 5, 2013
    550
    Media:
    2
    437
    Gender:
    Male
    Toronto
    Vehicle?:
    Challenger SS
    Model Year?:
    2015
    Trim?:
    SXT
    Color?:
    TorRed
    Transmission?:
    8-Speed Auto
    Make sure both your fog-lites are working!
  5. BAD GRANDPA
    BAD GRANDPA How fa$$$t do want to go? Site Supporter Level 5 Military Public Safety
    Apr 4, 2011
    4,708
    3,843
    Gender:
    Male
    Oswego, Illinois
    Vehicle?:
    Challenger R/T
    Model Year?:
    2010
    Trim?:
    Mopar 10
    Color?:
    Brilliant Black
    Transmission?:
    Auto
    If the previous owner replaced the OEM tail light bulbs (3057K) with LEDs and didn't wire in resistors, they will flash rapidly like you've described. Check to make sure your tail lights are bulbs and not LEDs. (Or you might be low on blinker fluid) :p..Oh yeh, Welcome to the Forum from Illinois! :cool:
  6. cudatude
    cudatude New Member Military
    Oct 10, 2017
    71
    87
    Gender:
    Male
    sacramento,ca
    Vehicle?:
    challenger SRT
    Model Year?:
    2011
    Trim?:
    SRT-8
    Color?:
    Toxic Orange
    Transmission?:
    Auto
    Could be the flasher relay or bad ground- - - - - -
  7. Shaker 392
    Shaker 392 Member
    Sep 3, 2017
    220
    Media:
    8
    166
    Gender:
    Male
    Columbus, Ohio
    Vehicle?:
    Challenger
    Model Year?:
    2017
    Trim?:
    R/T Scat Pack Shaker
    Color?:
    Yellow Jacket
    Transmission?:
    8-Speed Auto
    Hello and welcome to the brotherhood of muscle, go Bucks. As far your blinkers go have no clue, though maybe check all exterior lamps, ie license plate lamps.
    ann10 likes this.
  8. TheOldGuy
    Oct 22, 2013
    1,790
    Media:
    19
    Albums:
    2
    3,104
    Gender:
    Male
    Vehicle?:
    Challenger 2016
    Trim?:
    R/T Scat Pack
    Color?:
    Transmission?:
    6-Speed
    These cars have no flasher relay. The on-off of the blinkers is controlled by the PCM. The sound you hear is a small speaker under the dash to simulate a clicking relay.
    jklotz10, MOPARMOM and bad8nti like this.
  9. ann10
    ann10 New Member
    Nov 11, 2017
    5
    2
    Gender:
    Female
    Texas
    Vehicle?:
    RT CHALLENGER
    Model Year?:
    2010
    Trim?:
    Mopar 10
    Color?:
    Dark Titanium
    Transmission?:
    8-Speed Auto
    They alternate. I was hoping it was that so I could finally get fixed cause it’s annoying lol
  10. ThEoRy
    ThEoRy Member
    Mar 21, 2016
    441
    Media:
    10
    Albums:
    2
    549
    Gender:
    Male
    NJ
    Vehicle?:
    Challenger
    Model Year?:
    2015
    Trim?:
    Color?:
    B5 Blue
    Transmission?:
    8-Speed Auto
    Obligatory
    [​IMG]
    ann10, tripper1, TJGS and 2 others like this.
  11. TheOldGuy
    Oct 22, 2013
    1,790
    Media:
    19
    Albums:
    2
    3,104
    Gender:
    Male
    Vehicle?:
    Challenger 2016
    Trim?:
    R/T Scat Pack
    Color?:
    Transmission?:
    6-Speed
    OK... Now that we know that they alternate between bright and dim, It's a problem with the ground bus on the tail lamps. I don't know your technical abilities, however I'll explain. The tail lamp bulbs as well as the front directional/parking lamp have a dual filament setup with a common ground. One of the filaments is heavier than the other and requires more current to drive it. This is the brake/directional side of the bulb. The skinny filament is for the tail lamp and parking lamp in the front. The directional assembly in the steering column is a complex circuit allowing the brake and directional to function together if the directional is operating on either side while the brake pedal is depressed. Otherwise, the brake lamp flashes to provide direction indication. OK, we got that.
    When the ground is at fault on the rear tail lamps, the current finds the least resistance path back through the directional circuitry causing the tail lamp filament to provide that path of least resistance. Suffice it to say that you need to investigate the tail lamp assemblies to see where the green wire that attaches to the body of the vehicle had come off, broken, removed by accident, corroded, used as a stereo ground, been monkeyed with, or some other reason. Lots of times, somebody will replace a tail-lamp bulb and accidentley break the wire and not fix it thinking it don't matter. Or.... somebody did some wiring in the trunk area for whatever reason and now you have the blinker problem.
  12. ann10
    ann10 New Member
    Nov 11, 2017
    5
    2
    Gender:
    Female
    Texas
    Vehicle?:
    RT CHALLENGER
    Model Year?:
    2010
    Trim?:
    Mopar 10
    Color?:
    Dark Titanium
    Transmission?:
    8-Speed Auto
    Can I just take it somewhere so they can fix it? But where?
  13. ann10
    ann10 New Member
    Nov 11, 2017
    5
    2
    Gender:
    Female
    Texas
    Vehicle?:
    RT CHALLENGER
    Model Year?:
    2010
    Trim?:
    Mopar 10
    Color?:
    Dark Titanium
    Transmission?:
    8-Speed Auto
  14. ann10
    ann10 New Member
    Nov 11, 2017
    5
    2
    Gender:
    Female
    Texas
    Vehicle?:
    RT CHALLENGER
    Model Year?:
    2010
    Trim?:
    Mopar 10
    Color?:
    Dark Titanium
    Transmission?:
    8-Speed Auto
    imagine if I didn’t know any better and showed them this picture at autozone
    BAD GRANDPA and jklotz10 like this.
  15. BAD GRANDPA
    Apr 4, 2011
    4,708
    3,843
    Gender:
    Male
    Oswego, Illinois
    Vehicle?:
    Challenger R/T
    Model Year?:
    2010
    Trim?:
    Mopar 10
    Color?:
    Brilliant Black
    Transmission?:
    Auto
    That's a tough one!...JMO: Call a few auto repair shops in your area (including a Dodge dealership). Ask what their hourly rate for trouble shooting electrical issues is. Most places charge a minimum of one hour just to get started (even if it takes them 5 minutes to fix your problem). From my experience, it could take 5 minutes :) or 5 days :(. A lot depends on the skills of the technician. Computer controlled electronics on these cars can be a real PITA, especially if the previous owner was messing with them. Hope your issue is corrected in the first hour. ;)
  16. jklotz10
    jklotz10 Well-Known Member Member Relations MOTM Winner!
    Jan 26, 2011
    9,620
    Media:
    73
    Albums:
    5
    4,008
    Kewaskum, WI
    Vehicle?:
    2010 CHALLENGER
    Trim?:
    R/T Classic
    Color?:
    Plum Crazy
    Transmission?:
    Auto
    ^^^^^^^^^^^This^^^^^^^^^^
    Check to see if you have any 'speed' shops in your area who specialize in Kustom rides. They are more apt to be able to deal with the electronic issues as they have probably done their share of swapping modern engines / transmissions with computers (ECM / TCM) into older cars. They most likely have the skills that would be lacking at say a Midas or CarX type of place.
  17. TheOldGuy
    Oct 22, 2013
    1,790
    Media:
    19
    Albums:
    2
    3,104
    Gender:
    Male
    Vehicle?:
    Challenger 2016
    Trim?:
    R/T Scat Pack
    Color?:
    Transmission?:
    6-Speed
    Because the original poster has clearly identified the problem, This is NOT an issue with the PCM or other electronic device. Alternating dim-bright directionals is a simple issue of a missing ground. Any mechanic past the age of 50 has seen it a hundred times or more. When the ground is missing, the current path of the heavy brake/blinker filament now finds it's path to ground through the smaller tail lamp filament, through the headlamp switch and to ground. The increase in flasher speed is caused by the additional resistance/load of the longer path and the additional filament. I suggest the owner of said vehicle look around near the tail lamps in the trunk area as well as the ones mounted on the trunk lid to see if any wires look out of place. There is also the remote possibility that a front signal lamp may have lost its ground connection. Has anyone monkeyed around under the hood near the lamps which are adjacent to the regular headlamps? Has any work been done that corresponds to the time when the problem started? This could avoid an unnecessary expense.
    Even if you know nothing about cars, you may be able to identify the problem. You would also be surprised to see how many times over the years something heavy banging around in the trunk has torn off or loosened ground wires. Be a spy.
Share This Page
