1 - 4 of 4 Posts
I looked, but failed to find this issue discussed prior... I just got my car washed, and was ready to leave the car wash. And now the parking brake light is flashing on the dash. I pull the release again thinking, hey, I'm old, maybe I forgot to release it. Nope. The car is running, so I try to move. It drives fine, except for the annoying flashing red light and the occasional warning beep. Now here is gets stranger, I pull up to stop light and put on the parking brake and the light goes out. So I release it, and the light come back on. OK, WTF! I also tried to move with parking brake on (light off), brake is working fine, car would not move and almost stalled. Has anyone else had a similar issue? Is there a simple solution, maybe a wire to cut?? I'm not above the possibility of 'rednecking' it to make it work.
Thanks
Steve
How fa$$$t do want to go?
The brake light also functions as a brake system trouble light. Possibly one of the brake sensors got soaked. If it doesn't dry out by morning and turn off the light, a dealership visit may be in your future. The owner's manual states, if the brake light comes on, along with the ABS light, then you have a serious brake malfunction. Hope that dry Texas air does it's magic overnight.
Goods heads up....
My Jeep did that once. Turned about the brake fluid was low. Something to check
Reactions: BAD GRANDPA
1 - 4 of 4 Posts
