I have a 2016 Challenger RT. I'm at about 30000 miles and decided it'd be a good idea to just check up on the spark plugs (NGK iridium spark plugs LZFR5CI-11), especially since I'm not doing anything else over this quarantine. When I finally took out all the spark plugs, all 16 spark plugs were completely carbon fouled. Just dry, pitch-black soot on the top. These plugs should be good for much longer than 30000 miles, but I went ahead and ordered new ones after seeing how badly carbon fouled they were.
My theory is that because I went catless without a tune and without O2 simulators/spacers (have been running with the CEL on for about 2-3 months) it screwed up the air-fuel ratio from the O2 sensors and caused the engine to run really rich, which ultimately caused the carbon-fouled spark plugs.
Does this sound at all plausible? I don't know a whole lot about cars and I'm still trying to learn as much as I can, but I can't think of any other reason why the spark plugs are this messed up just after 30000 miles (I occasionally have fun with the car and drive it a bit hard, I must admit, but I try not to do it all that often). If this is the reason, would getting O2 simulators/spacers fix the issue and air-fuel ratio?
Any advice or feedback is appreciated. Thank you!
