Funny you should post this. I was about to create a new thread about something very similar that has happened to me.
Twice in the past two weeks, I got in my car and pressed the Start button. The car turned over and started but died a second later and kept the engine turning for another five seconds trying to start. I have an auto transmission. The first time, I tried several more times with the same result. I noticed the red light Alarm indicator located in the black area below the "F" on the fuel gauge would stay on. I waited about five minutes and tried once again. It started.
This morning, it happened again, and the Alarm red light was on as well. I took my foot off the brake and cycled (with the start button) through the accessory mode, ignition on, etc. Then, I put my foot on the brake and it started. The battery, in both instances, seemed to be cranking well. I just wonder if it is a fuel pump or spark issue that is behind it.
I know if I take it to the dealer they won't be able to replicate the issue and send me home. I guess I have to wait until the problem becomes permanent before they will figure it out, or even try.
