If you put a hitch on your SP you should be banned from ever owning one again.Has anyone installed a Class 3 trailer hitch on your Scat Pack with the active exhaust ?
I read that they will NOT fit our Challengers with the active exhaust
I guess I could mount my canoe to the roof, but I would rather trailer it aroundIf you put a hitch on your SP you should be banned from ever owning one again.![]()
You’re crushing my dreams, LOL
Either way I would have bought it. This is the first vehicle I have owned in years that I love to drive.
My dealer did say the max towing 1000 lbs with a 350 lb tongue weight. My trailer is well under 400 lbs with the canoe.
They offered to install a class 3 hitch for $500. But I thought I would just do it myself and save some money, but when I started looking I found reviews stating they would not fit with the active exhaust.
So I thought I would ask if anyone had added a hitch.
Good fabrication skills cures all that. The frame of the GT the hitch was added on now contains about 80 pounds of gussets and square tubing. It took over 6 hours to fabricate and weld. After they got everything painted, he lifted the rear of the car off the ground with the forklift with a chain around the ball. There wasn't the slightest deflection of metal anywhere. Anybody ever rear-ends that Challenger, their vehicle will be destroyed. And of course I realize Joe & Sally Average are at the mercy of total junk commercially available hitches and Bozo installers such as U-Haul.Well, you can rely on your dealer if you want, but again, my manual. says no towing, so that means there is no 'limit' for the dealer to tell you.
And there is a big difference in total weight (1000 lbs ) and tongue weight (350 lbs), a 350 lb tongue weight sounds high as most trucks are only 500 lbs, and they are designed for towing, where as the challenger only has sheet metal to attach the hitch to, not a real frame.
Can you make it look like this rendering?Has anyone installed a Class 3 trailer hitch on your Scat Pack with the active exhaust ?
The RAM TRX was a little out of my price range...Sell it and get a truck...![]()
