1 - 4 of 4 Posts
2009 RT Challenger with Kooks Headers, High flow cats throwing Codes P013A, P013C intermittently. Any idea why it's throwing these codes? Also has CEL Eliminators on both 02's after cats.
"When an OBD-II equipped vehicle has a stored P013A code, it means that the powertrain control module (PCM) has detected a slow response time from the downstream (or post catalytic converter) oxygen (O2) sensor or circuit for engine bank one. Bank 1 specifies the bank of the engine which contains the number one cylinder."
The "C" on the second code means Rich to Lean (Bank 2 Sensor 2).
P013A = Oxygen Sensor Slow Response Rich to Lean Bank 1 Sensor 2
P013C = Oxygen Sensor Slow Response Rich to Lean Bank 2 Sensor 2
What is causing these codes?
1 - 4 of 4 Posts
