It will also reset the Adaptives in your PCM, which isn't a bad thing.You may want to pull the radio fuse before disconnecting the battery. Can't remember why, saw it recommended in a thread a while back. You'll only need to reset the clock as the radio will keep your presets.
I dont know what that means . Could you please explain . Thanks . BooBooIt will also reset the Adaptives in your PCM, which isn't a bad thing.
