Drum Brakes to 4 wheel power disc conversion
Discussion in 'Classic (70's) Dodge Challenger' started by Tonycuc, Apr 10, 2017.
  1. Tonycuc
    Tonycuc New Member
    Mar 22, 2017
    5
    2
    Gender:
    Male
    FL
    Vehicle?:
    Challenger
    Model Year?:
    1970
    Trim?:
    R/T
    Color?:
    HEMI Orange
    Transmission?:
    6-Speed
    I'm in the process of installing 4 wheel disc brakes on my 70 challenger R/T. While the install is finished, my 15" wheels are hitting the caliper and can't be put back on. does anyone have any idea or experience with this problem?
  2. Cuda SRT8
    Cuda SRT8 Member
    Mar 20, 2010
    115
    16
    East S.F. Bay Area
    Vehicle?:
    2010 B5 Classic
    Trim?:
    R/T
    Color?:
    B5 Blue
    Transmission?:
    Auto
    It sounds like you've installed an aftermarket conversion kit and are installing original wheels or even aftermarket 15" wheels when the kit will only accept 16" or 17" wheels.
    Will the wheels fit on the rear (usually smaller calipers)? You're either going to need to change to a 17" wheel / tire combo or possibly have you stock wheels cut and re-welded with the necessary offset to move the "step" in the barrel out away from the caliper.
    I once did this when putting '70 rally wheels on a '73 Dodge van. A place called Stockton Wheel in Stockon Calif can do this. They put the wheel on a lathe and cut the welds; moved the center out to your provided measurement and re-weld. This was a long time ago, but I believe they are still in business.
    Good luck
    FastMikeR1 and BAD GRANDPA like this.
  3. Drewcrane
    Drewcrane Member Photo Winner!
    Jan 18, 2014
    470
    Media:
    1
    308
    Colorado
    Vehicle?:
    2012
    Trim?:
    R/T Classic
    Color?:
    Tungsten Metallic
    Transmission?:
    Auto
    What did you use for brakes factory or ? I did the same thing on our vintage cuda and challenger,used wilwoods and 15,s will mount on no problem did you go larger than 10.75 for rotors? I am running 17,s on the cars now,so yes you might have to consider a wheel change
    BAD GRANDPA likes this.
  4. Tonycuc
    Tonycuc New Member
    Mar 22, 2017
    5
    2
    Gender:
    Male
    FL
    Vehicle?:
    Challenger
    Model Year?:
    1970
    Trim?:
    R/T
    Color?:
    HEMI Orange
    Transmission?:
    6-Speed
    thanks, I found out I have to change the rims as they are for drum brakes only. thanks for your answer, i had a feeling but wasn't sure.
    Drewcrane and BAD GRANDPA like this.
  5. deano379
    deano379 Member Public Safety
    Apr 2, 2012
    286
    Media:
    1
    621
    Utah
    Vehicle?:
    11 Challenger
    Trim?:
    SRT-8
    Color?:
    Black
    Transmission?:
    Auto
    I changed the drums on my 63 Plymouth Savoy to the OE 70s disc in front. Both the OE 15X5 1/2" and 15X6" steel wheels fit OK.
  6. Tonycuc
    Tonycuc New Member
    Mar 22, 2017
    5
    2
    Gender:
    Male
    FL
    Vehicle?:
    Challenger
    Model Year?:
    1970
    Trim?:
    R/T
    Color?:
    HEMI Orange
    Transmission?:
    6-Speed
    I found out there are different factory rims for drum & disc brakes so I ordered 5 new rims as I want to keep the factory wheels & tires.
  7. Dodgeguy
    Dodgeguy Highway Star Site Supporter Level 1 Member Relations Photo Winner! MOTM Winner! Public Safety
    Jul 11, 2010
    26,231
    Media:
    63
    Albums:
    4
    30,597
    Gender:
    Male
    Tucson
    Vehicle?:
    2010 Challenger
    Trim?:
    R/T
    Color?:
    HEMI Orange
    Transmission?:
    6-Speed
    I never ran into that before but it is possible. I switched to discs on a 71 and had no issues with the wheels.
  8. BlueStreakBob
    BlueStreakBob Active Member
    Apr 8, 2012
    1,919
    Media:
    6
    104
    Near Chattanooga TN
    Vehicle?:
    '12 Challenger
    Trim?:
    SRT-8
    Color?:
    Blue Streak Pearl
    Transmission?:
    Auto
    With after market big disc brake set ups, it is necessary to step up the wheel diameter and with some it will take a special wheel to fit the calipers behind the wheels regardless of offset. Be prepared to do some searching to get the proper set of wheels.
  9. cdahl383
    cdahl383 Senior Member MOTM Winner!
    Mar 4, 2012
    10,767
    Media:
    82
    Albums:
    5
    7,365
    Gender:
    Male
    Detroit, Michigan
    Vehicle?:
    2015 Challenger
    Trim?:
    R/T Scat Pack
    Color?:
    Sublime
    Transmission?:
    8-Speed Auto
    I did the conversion on my 72 Nova in the front, but I went with a kit from Wilwood that fit with 15" rims. Most aftermarket brake kits are made for 16-17" rims or bigger. Sounds like you either need different rims or you need to order a kit that is made to fit 15" rims.
Share This Page
