1 - 12 of 12 Posts
Today i i stalled 3in Dynomax mini bullets(#24250) on my 5.7 shaker STP 6M. I already had resonator deletes but with the stock mufflers and that sounded too high pitched for me. The sound is great but i do feel like the car's torque is not as it was before but i will be pulling the #2 fuse and hoping that fixes the problem. The first video will be of the stock mufflers with resonator deletes and the second with 3in dynomax mini bullets and resonator deletes.
Discussion Starter #2
Update. Pulling the #2 fuse is for older challengers. for 15+ (i believe 15+ definitely 16+) it is the #31 fuse. seems to almost be back to normal or i'm probably just over thinking it. Exhaust sounds great and well worth it!
I didn't notice any loss of torque on my 6.4L with the bullets, but I guess anything is possible. If there is a loss of torque from backpressure loss, the *worst* setup should be the full delete.
Sounds good! Where did you place Bullets? Where the mid mufflers are, and then straight pipe out?
JS
Yes, i replaced the mid mufflers with the mini bullets, and then straight piped out. i will say that it does sound very blatty if you get on it and hat starts at around 4500 rpms.
2012 RT Redline Tri Coat
Sounds goooooood!
LOL! I actually had to look-up the word "blatty." So basically it rattles a lot at high RPM? How is the cabin noise; is there a lot of drone? I have the 8-speed-auto, so I am expecting it to sound like crap when the MDS is on. Currently I have only deleted the rear resonators, and it sounds good. I would just like to give it a little more bark without spending a bunch.
Discussion Starter #9
the way i think of blatty is it sounds like bursts of exhaust are coming out instead of a continuous stream. Not sure if that really makes sense. i took the bullets off because i really disliked that part and put the stock mufflers back on and left the resonators off.
^^^ No issue for me. Not sure if you would call it drone or just louder exhaust :) I think if you want it louder, you want to hear some of it inside and carry on a regular conversation too. I know it sounds better and don't need to turn up the sound system volume to compensate.
1 - 12 of 12 Posts
