I have a red warning showing up on my dash lately. It's a lightning bolt surrounded by curved vertical lines on each side, like reversed parenthesis. The manual states it is "electronic throttle control" I assumed it meant the cruiser control, but it's working properly. Does anyone know what it might be? Thanks.
That sounds like a throttle light for the input from the pedal most likely, can be cause by a bunch of things, strange that the cruise would still work with it on though
Try cleaning the throttle body and doing a relearn procedure. You really need to pull the codes to see if its a tb issue or gas pedal issue
It's usually the throttle body.
