1 - 11 of 11 Posts
Discussion Starter · #2 ·
Flowmaster is proud to announce that our Original 40 Series muffler will soon be available in three all new configurations.
Available: July 1, 2016
Part #425404
Flowmaster 2.50” IN(D) / OUT(D) Original 40 Series Muffler
Part #42442
Flowmaster 2.25” IN(C) / OUT(O) Original 40 Series Muffler
Part #42542
Flowmaster 2.50” IN(C) / OUT(O) Original 40 Series Muffler
Application:
Universal Fit
Features:
Original 40 series mufflers deliver an aggressive exterior and interior tone. If you’re looking for that original Flowmaster sound, these are the mufflers for you. Constructed of 16 gauge aluminized steel and fully MIG welded for maximum durability.
• Durable Fully Welded 16 Gauge Aluminized Steel
• Aggressive Sound Exterior Exhaust Tone
• Noticeable Interior Resonance
• Excellent Street/Strip and Off Road application
• Made in the USA
Please call 707-544-4761 or visit www.flowmastermufflers.com for additional application and product information.
Discussion Starter · #4 ·
Available: October 1, 2016
Flowmaster 3.00" IN/OUT Outlaw Race Muffler (Part #15430)
Flowmaster’s new 3.00 inch Outlaw Race Muffler is intended for race classes requiring mufflers but do not have a set sound reduction rule. The muffler has a 4.00 inch diameter body that is 10.50 inches long. The muffler is constructed with 16ga aluminized steel and manufactured in the USA.
• Aluminized Steel Construction
• Aggressive Performance Tone
• Race Proven Technology
• Made in the USA
Flowmaster 3.00" IN/OUT Outlaw Shorty Race Muffler (Part #15430S)
Flowmaster’s new 3.00 inch Outlaw Shorty Race Muffler is intended for race classes requiring mufflers but do not have a set sound reduction rule. The muffler has a 4.00 inch diameter body that is only 6.50 inches long. The muffler is constructed with aluminized steel and made in the USA.
• Maximizes Exhaust Scavenging
• Compact, Lightweight Design
Discussion Starter · #6 ·
Flowmaster New Product Releases
Available: November 1, 2016
Flowmaster Super 10 Series Cross-flow Muffler (2.50” In/Out, 409S) - Part #8425810
Flowmaster’s latest version of its popular Super 10 Series muffler is now offered in a Cross-flow design. This 409S stainless steel muffler is designed to be mounted transversely and has a 2.50 inch inlet and dual 2.50 inch outlets. Like all Super 10 Series mufflers, this single chamber design delivers a powerful and aggressive tone inside and outside of the vehicle. This muffler is built in the USA and is backed by Flowmaster’s Lifetime Limited Warranty.
• Stainless Steel Construction
• Most Aggressive Tone Available
• Made in the USA
Flowmaster Chambered Technology
Flowmaster American Thunder Dual Mode Axle-back Exhaust System (NPP) for 2016-2017 Camaro SS 6.2L - Part #817746
Flowmaster’s American Thunder Axle-back system for the 2016-2017 Camaro SS with the 6.2L V8 engine is perfect for the person looking for a powerful and aggressive sound quality in Track mode, while maintaining a mellow tone during Stealth mode. This kit features tandem Delta 40 and Outlaw mufflers and 4.00 inch polished stainless steel tips. Includes functional exhaust valves to work with the OE actuator motors to select between sound levels. The exhaust system is manufactured in the USA with 409S stainless steel and is covered by Flowmaster’s Lifetime Limited Warranty. Designed for an easy fit on both coupe and convertible models with the factory NPP option (identified by quad tips). The system includes all necessary parts and hardware for installation.
Note: The system is a clamp-on, however, OE system will require cutting to remove factory mufflers.
• Dyno Tuned For Maximum Performance
• Dual Mode Operation
• Made in the USA
Flowmaster Outlaw Axle-back Exhaust System (DOR) for the 2012-2016 Jeep Wrangler 3.6L V6 - Part #817752
Flowmaster’s Outlaw Axle-back exhaust system for the 2012-2016 Jeep Wrangler with the 3.6L V6 is perfect for the person looking for an aggressive exterior and moderate interior exhaust tone, with all of the performance benefits that you would expect from Flowmaster. This bolt-on DOR (Dual Out Rear) emissions-legal system for the 2 and 4 door models, features a specially designed stainless steel Outlaw Series muffler and dual 2.50 inch mandrel bent tailpipes. The system finishes with 4.00 inch black ceramic coated stainless steel tips. The exhaust system is manufactured in the USA with 409S stainless steel and is covered by Flowmaster’s Lifetime Limited Warranty. Designed for an easy fit, this system includes all necessary parts and hardware for installation.
• Contemporary Black Styling
• Dual Exit Tailpipes
• Made in the USA
Flowmaster Delta-Boost Module for Ford 2.3L EcoBoost - Part #18101
Flowmaster’s Delta-Boost Module is a simple way to gain up to 4 extra psi in boost pressure with an easy to install plug and play unit on Ford’s 2.3L EcoBoost engine. The module simply installs in-line with the boost sensor and ECU and is controlled by a downloadable Bluetooth app from your smartphone. The Delta-Boost Module offers 4 different settings: Valet, Standard, Sport, and Max. The module is built in the USA and backed by a 1 year warranty.
• Bluetooth Controlled
• Quick and Easy Installation
• 4 Performance Levels to Choose From
• Made in the USA
Flowmaster Delta-Boost Module for Ford 1.0L, 1.6L, and 2.0L EcoBoost - Part #18102
Flowmaster’s Delta-Boost Module is a simple way to gain up to 4 extra psi in boost pressure with an easy to install plug and play unit on Ford’s 1.0L, 1.6L, and 2.0L EcoBoost engine. The module simply installs in-line with the boost sensor and ECU and is controlled by a downloadable Bluetooth app from your smartphone. The Delta-Boost Module offers 4 different settings: Valet, Standard, Sport, and Max. The module is built in the USA and backed by a 1 year warranty.
• Made in the USA
Flowmaster Delta-Boost Module for Ford 2.7L EcoBoost - Part #18103
Flowmaster’s Delta-Boost Module is a simple way to gain up to 4 extra psi in boost pressure with an easy to install plug and play unit on Ford’s 2.7L EcoBoost engine. The module simply installs in-line with the boost sensor and ECU and is controlled by a downloadable Bluetooth app from your smartphone. The Delta-Boost Module offers 4 different settings: Valet, Standard, Sport, and Max. The module is built in the USA and backed by a 1 year warranty.
• Made in the USA
Flowmaster Delta-Boost Module for Ford 3.5L EcoBoost - Part #18104
Flowmaster’s Delta-Boost Module is a simple way to gain up to 4 extra psi in boost pressure with an easy to install plug and play unit on Ford’s 3.5L EcoBoost engine. The module simply installs in-line with the boost sensor and ECU and is controlled by a downloadable Bluetooth app from your smartphone. The Delta-Boost Module offers 4 different settings: Valet, Standard, Sport, and Max. The module is built in the USA and backed by a 1 year warranty.
• Made in the USA
Discussion Starter · #7 ·
Flowmaster Outlaw Axle-back Exhaust System for the 2014-2017 Chevrolet Corvette Stingray w/ 6.2L V8 Engine - Part #817754
Description:
Flowmaster’s Outlaw Axle-back system for the 2014-2017 Chevrolet Corvette Stingray with the 6.2L V8 engine, is perfect for the person looking for a powerful and aggressive sound quality. This kit features resonator style mufflers to maintain a comfortable tone inside the car, while providing a deep performance tone outside. This system includes 4.00 inch polished stainless steel quad tips. The exhaust system is manufactured in the USA with 409S stainless steel and is covered by Flowmaster’s Lifetime Limited Warranty. Designed for an easy fit, this system includes all necessary parts and hardware for installation. This kit is designed to clamp-on, however, does requires cutting of OEM system.
Note: This kit does not fit vehicles with Bi-Mode exhaust option.
• Proven Flowmaster Technology
• Made in the USA
Flowmaster American Thunder Cat-back Exhaust System for the 2011-2017 Chevrolet/GMC Silverado/Sierra 1500 with 6.2L V8 Engine - Part #817602
Description:
Flowmaster’s American Thunder Cat-back exhaust system for the 2011-2017 Chevrolet/ GMC Silverado/Sierra 1500 pickups (Crew Cab and Double Cab) with the 6.2L V8 engine is perfect for the person looking for an aggressive exterior sound level while maintaining a moderate interior sound with all of the performance benefits that you would expect from Flowmaster. This bolt on 409S stainless steel system features a 3.50 inch inlet pipe assembly that runs into a 50 HD Series muffler. The systems uses 2.50 inch mandrel bent tailpipes for maximum performance and then is finished off with 3.50 inch polished stainless steel tips with embossed Flowmaster logos. This dual exit system can be exited out each side or straight out under the rear bumper. The exhaust system is manufactured in the USA and is covered by Flowmaster’s Lifetime Limited Warranty. Designed for an easy fit, this system includes all necessary parts and hardware for installation.
• Patented Delta Flow Technology
• Made in the USA
Here is a list of black exhaust tips that have been added to our product line-up:
15315, 15316, 15318B, 15368B, 15377B, 15397B, 15398B
If you have any questions, please contact me:
Bob Payne
[email protected]
(707) 544-4761 extension 441.
Flowmaster Delta Force Replacement Original Equipment Panel Air Filter for 2011-2018 Dodge Challenger, Charger & Chrysler 300 with 3.6L/5.7L/6.4L Engines
Available October 1, 2018
Part #615028
Application:
Features:
The Delta Force OE replacement panel style air filter is a great way to add some performance to the 2011-2018 Dodge Challenger, Charger and Chrysler 300. Similar to the other filters in our Delta Force line, these premium quality filters features a durable black urethane outer frame/seal and a red woven cotton gauze filtration media. They come pre-oiled and ready to install. As oiled filters, they will require routine maintenance that can be performed with our cleaning kit (615001).
• Serviceable with Delta Force Cleaning Kit
• Double Layered Woven Cotton
• Replaces Stock Air Filter
• Flowmaster Quality
Questions? Please call 707-544-4761 or visit www.flowmastermufflers.com for additional application and product information.
Flowmaster Aluminum Heat Shield Kit for All 40 Series Mufflers – Part #51013
Available November 1, 2018
Part #51013
Application:
Fits all 40 Series Flowmaster mufflers, may fit additional applications.
Features:
This custom designed aluminum heat shield is pre-formed to fit all 40 series mufflers. Adding a heat shield to your muffler gives added protection in reducing heat radiated from mufflers and also helps reduce interior noise. May fit all mufflers with an approximate case thickness of 4.00” to 5.00” tall, 10.00” wide and 13.00” in length. Attaches easily with included stainless steel muffler straps.
• Added Protection to Vehicle Floor Boards
• Lightweight Aluminum Construction
• Dissipates Heat Quickly
• Reduces Interior Noise
1 - 11 of 11 Posts
