Got any pixs of those lights ? Are they brighter & do they burn out quickerI put the switchback led's in mine. The drl's run yellow unless you have the headlamps on, then they burn white. When you use the turn signal, they flash yellow so they are legal.
I checked, Sylvannia has these which I'm guessing is OEM...It is a 3157A if I remember correctly. There are LED options but I didn't want to get into the possible LED problems with load resistors, etc. I did "sputter" some aluminum paint on the top (tip) of the bulb to eliminate the egg yolk look when parked. I tried some of the silvered lamps available on the market first and they burned out quickly. I would just replace with a 3157 to get a white light but we have to have amber by law.
For fogs, can I just get these to sorta match my HID's ? any input on on these for replacement fogs ?Don't have any pics but they are led so you have to install resisters and should last way longer than regular bulbs. If you don't have drl's they burn white all the time except when turning, then yellow.
For those of you that have the drl's activated and still using regular bulbs, my sockets were starting to burn. I assume since the drl uses the bright side filament it will overheat the socket over time.
