Indeed. The reason for my post is that we have a second tier fuel supplier named GoGas. They have 93 octane non-ethanol, and I'd like to use this in my SP. However, I do know that top tier fuels use more detergents in their fuels; above the EPA standard. I have used Techron for years and it seems to be good stuff. But, I wonder if one or two bottles of it would supply the same detergent levels as found in a tank of top tier fuel? I called the supplier for GoGas and no one could tell me what I wanted to know and they said they would call me back.
Up to you of course, but I wouldn't bother to try to treat every tank of gasoline to a dose of Techron in some attempt to blend my own Chevron like gasoline.
Not sure what the ratio of the good Techron concentrate to X number of gallons of gasoline would be to approximate what Chevron gasoline has to offer.
You can experiment. Do the full Techron treatment, at least one bottle's worth mixed with gasoline according to the directions on the Techron bottle. If the engine reacts favorably to the treatment repeat a 2nd time. Then change the oil/filter.
If the engine reacts favorably then you know the engine had developed some deposits that were affecting engine performance. Now you know that at least before every oil/filter service running a bottle of Techron through the engine is a good idea.
If the engine doesn't react favorably then maybe the gasoline you are buying ain't so bad after all.
Or your usage helps keep the engine clean.
Over 3 or 4 decades, I have found that driving my cars (a '96 Mustang, 2006 GTO, a couple of Porsches) 50 miles (or up to couple of hundred miles) non-stop at highway/freeway speeds has had a beneficial effect on the engine. Most noticeably low end response seems better. The constant steady engine running appears to remove something that affects the engine and the engine responds by running better.
(So far I have not had the time to take either my 2018 Hellcat or my 2018 Mini JCW out on the open road for a 50+ mile drive. Both are relatively new cars with just over 7K miles on the JCW and not even 6K miles on the Hellcat.)
My regular usage of my cars doesn't involve 50+ miles (let alone 200 miles) of steady highway/freeway driving and I just don't have the time to do this on the weekend, not even one weekend a month.
But if your usage has you driving your car for say 50+ miles at steady highway/freeway speeds once in a while that might mitigate your use of a 2nd tier gasoline and Techron may not be necessary.
