I had this issue once in a while on a quick rev, however, once i installed my procharger, 60lb injectors, and 400lph fuel pump (diabli I3+unlocked pcm), its gotten much worse. My tuner has tried 3 diff tunes.
i watched the youtube video on the emissions tie in which what my dealer said.
is it possible to go back to a manual cable operated throttle body?.
yes. twice.
i keep getting injector open circuit codes. Pullinh injectors to test soon.
what else? throttle body?
2017 TA Green Go.
Could be. I had a 2016 v6 mustang that had a bad TB. No codes but a new TB solved all the weird issues it was having.
Interesting. I took the car to the dealer when itwas stock, and i was told the hanging idle on quick revs was because of the emiisions crap. I guess ill look at some throttle bodies
Vacuum leak somewhere? I had the same issue when I put my SC on, it was not always.
Check your EVAP lines for connections?
Reactions: SmknDezl
