Move your passenger side seat up all the way. Now check the connection under there to make sure it's on all the way.
I had the same issue with my car. One day they just quit working. Looked it up online, turns out the connection under the passenger side seat can come loose or undone.
Mine looked like it was on all the way, but I just pushed it together really good again anyway. Pushed the button and they both worked, haven't had a problem since. This problem can happen more so when you use the back seat more often and move the passenger seat back and forth, etc.
Check that first, it's literally a 30 second fix. After that I would go to fuses, etc.
