1 - 18 of 18 Posts
This is probably a topic that has been beat, but I wanted to post a photo of the results of the Hellcat lower airbox, Hellcat air filter, and headlamp air duct. I had my cruise set at 63 mph and this is what the gauges were showing. Notice the intake air temperature relative to the outside ambient temperature. Not too shabby! At least I don't have to worry about heat soak.
How's it possible that the IAT is 15 degrees cooler than ambient ? I can only figure if you had AC air being ducted in.
I've got the set up and shaker and I'm + 3-5 over ambient
Did you get it from a dealership or somewhere else? Can you give me the part numbers and cost?
I got mine from a dealer before I actually picked up my car, and I don't remember, but one place was way cheaper than anyone else. I went with the AFE plastic air duct, the factory one is pretty flimsy. The box, duct, and Hellcat filter were about $100 total.
Is there any problems with driving the car in heavy rain after installing the Hellcat Airbox? It only makes sense that if air gets in, that water can also.
Well, since the Hellcat/Demon drive OK in the rain, why would there be? if you look at how the box gets air into it, it's unlikely that water could possibly be an issue. In the old days, a mechanic friend of mine took a garden hose and capped it with his finger and sprayed water right into the carb to blow the carbon out of my '72 Cutlass. A LOT of water. No problems. It worked, and stopped the pinging it had since it was about a year old.
I bought the tube from ebay, for $39.99, mine has the square hole in the air box, it fit perfect.was a bit of a pain to get the filter and air box in and out, couldnt get hand in to put tube on headlight duct but a screwdriver from the front got it lined up. I have the Shaker so it gets air from that, the new tube, and the bottom of the airbox gets air from the lower grill.
244808
244809
Discussion Starter #15 (Edited)
Air scoop: Search results for "hellcat" | aFe POWER
Did not like the factory one and this one is $20 cheaper
Hellcat airbox: 2016-2020 Dodge Air Cleaner Body 68175164AC | DodgeParts.com
both for under $100 :)
Hi Danny. I am so sorry for my delayed response. I've not been here much lately and simply didn't see your post. It's late, but here are the numbers:
68175164AC Body, Air Cleaner (Lower – Hellcat) USE VIN 2C3CDZC93GH193092 (2016)
68207918AB Headlamp Intake Duct - MOPAR USE VIN 2C3CDZC93GH193092 (2016)
I included a VIN because so many dealers, especially online, want a VIN to ensure the correct part and in case you need to do a return.
Here are some other numbers I've collected just in case you might need something else:
Part # Description for SRT/HELLCAT
5LC53RXFAI Hellcat Rear Spoiler w/camera USE VIN 2C3CDZC93GH193092 (2016)
68406529AA Tire Pressure Sensor USE VIN 2C3CDZC95HH542643 (2017)
68020719AC Tire Pressure Monitor Sensor Hardware Kit
5ZW66VXWAC Wheel, Alloy –20X9.5 SRT LowGloss Black Perf Whl USE VIN 2C3CDZC95HH542643 (2017)
68172459AA Hellcat Air Filter
5038041AA SRT Oil Filter - Mopar Performance
68272122AA Cover, -ABS Control Unit
68248384AB SRT Front Brake Pads
68184587AB SRT Front Brake Rotor
68144223AA SRT Rear Brake Pads
05290538AC SRT Rear Left/Right Brake Rotors
Part # Description for Scat Pack/TA 392
6AD81DX9AA Steering Wheel- Perf Leather W Cruise Control USE VIN 2C3CDZFJ7HH640997 (2017)
68394689AA Nameplate – Mopar, (392 Scat Pack Bee, RH, 2019)
68394690AA Nameplate – Mopar, (392 Scat Pack Bee, LH, 2019)
6CZ27RXFAA Cap, Satin Black, Rhombi 2-Pc Wheel Center USE VIN 2C3CDZFJ9KH505902
68258730AB Front Fascia Challenger
68258747AB Front Air Dam
04861746AB 6.4L Air Filter
68071668AA Cabin Air Filter
SP196724AA Spark Plug 16 required
CERGUB41AA Canister-Vapor (UB4 Campaign)
52854283AA A8 Automatic Transmission Fluid
68234631AA Mopar Power Steering Fluid, Mopar
68171066PA Pennzoil Ultra Platinum 0w-40 Full Synthetic (7 quarts)
6507741AA Oil drain bolt (13mm hex)
6509873AA Lug nut (22mm hex or 5/8)
68214652AA Front Grill, Challenger Emblem
68254141AA Applique-Fascia - Mopar (Rear Center Gloss Black)
68175182AC Center Panel End Cover – RH (for rear center tail lamp)
68175183AC Center Panel End Cover – LH (for rear center tail lamp)
4857345AA Center Tail Lamp Assembly Fastener (Push pin)
6507357AA Tail Lamp Assembly Wing-Nut
68254140AA Rear DODGE Nameplate
6506132AA Engine belly pan push pin retainer
68242934AC Belly Pan, Front
6511907AA Steering Wheel Bolt
6505411AA Retainer, Trim, Trunk Lid M6.3X18.60
6505667AA Push Pin, Side Trim Panel, Cargo (Auveco #20360)
5038500AB Hose/Pipe, PCV
68169878AB Floor Cover, Cargo
4662032AD Side Trim Panel, Cargo, RIGHT
4662031AF Side Trim Panel, Cargo, LEFT
6506152AA Strut Mount Nut - Front
1SK35SZ0AA Cap, Chrome Center - 64mm/2.5” “Dodge” (2016)
ACCESSORIES (These are subject to change and availability)
82212567 Mopar Wheel Locks
82213744 Challenger Door Sill Guard
82213167 Floor Mat Kit, Floor (Challenger embroidered)
82214926AC Mat Kit, Carpet Cargo (Dodge Logo) **Challenger logo no longer available.
1QR33DX9AB Floor Mat, Mopar (OEM floor mat with silver Dodge embroidered)
Did the same thing, but drizzled auto tranny fluid instead of water...
I also have the Hellcat Airbox with no problems...and I also have the passenger side open with a DIPS screen with no water problems...
Discussion Starter #18
My dad use to do the same thing. He said he would certainly clean out the carbon!
1 - 18 of 18 Posts
