1 - 12 of 12 Posts
· Westbury JCDR
Some also have "remote start disabled" on the dash.
The dealership may need to reactivate it (if that is the cause of the problem).
Another could be the amount of fuel in the car, if its low, it won't remote start.
Another possibility could be that the car timed out on its initial remote start. You should try starting the car normally, shut it off, then remote start (its not a very likely cause of the issue though).
I'll edit this if I can think of anything else, these are just things I have already experienced.
Can you reset the computer in these cars by disconnecting the battery ground for 15 minutes ?
1 - 12 of 12 Posts
