1 - 9 of 9 Posts
2021 Challenger R/T SP WB M6
So I monitored IATs for schlitz and giggles - it hovered around 5 -7 degrees above ambient. Even after 1 hour of spirited driving and speeds around 75.
2015 Dodge Challenger SRT
Good numbers.
Do you have the stock airbox? Or a Hellcat airbox? Or, a Cold Air Intake?
That's on par with what I observe with my 2020 Scat Pack.
Actually if I start out from a cold start IAT can stay under 5F above ambient as long as I do not get into stop and go traffic.
IAT is elevated after parking the car this from heat soak. Normal. Doesn't take too much time for this to come down and if I leave surface streets for the highway the IAT really drops.
So far my 2020 Scat Pack's IATs are lower than that of any other N/A car I have owned.
Discussion Starter · #4 ·
Good numbers.
I put on the hellcat lower with headlight airtube. Stock other than that, it is the scoop that goes nowhere and dual heat extractor hood.
It looks like those heat extractors are doing their job.
I added the recent T/A-style cold air intake to my '15 SRT 392 a couple of years ago. That CAI makes the center hood scoop functional and ducts the air to the airbox. It also has a duct to the inner headlight so it's pulling air from a number of places.
My IATs usually run in the same 5 to 7 degrees above ambient when I'm cruising. Though ... last weekend when I made a trip from Jacksonville to Daytona Beach and back, the IATs hovered around 3 to 5 degrees. And ambient was in the 88 to 90 range that day. I really don't have an explanation for why the IATs were lower than usual.
Your numbers are what I'm seeing dead stock. I think the heat extractor hood probably does more for it than the headlight tube.
Scat Pack Shaker
Motor vehicle Automotive design Automotive decal Automotive exterior Font
Mine gets to 5 or 6° above outside temp at 60 mph after a minute too…
The question is what’s it at when yer in the staging lanes/water box/starting line/and most importantly 11 seconds later : )
Discussion Starter · #8 ·
I ran the car pretty hard for an hour - speeds up to 75 sustained for minutes at a time. Hard on ramp acceleration, no 1320 but it stayed consistent.
And when I used to race it was hood up, engine off. Move every 2 cars. But it depends on the amount of cars staged. Personally I would rather see what it looks like after a few laps on VIR or Summit Point, ETC... but I am not about to embarrass myself in this 4400lb car :)
Scat Pack Shaker
Dude that went 6.00 at Irwindale thursday night didn’t seem embarrassed…
Tire Motor vehicle Automotive tire Wheel Car
1 - 9 of 9 Posts
