Installed the E&G lovers last weekend. The only issue I had was with alignment. It's a little off. The right side is raised a little (bowed). I don't know if ii am going to try to fix it or not. It's not that noticeable.
Be advised that the louvers have sharp edges. I found out the hard way when I tried to reach through to dry the windows off. Ended up cutting myself.
This is the cheapest option for louvers. They run about $240. So your not out a ton of cash if you don't like them.
It does keep the interior cooler. There are no rattles and they attach firmly.
