Guaranteed Shipping on July 12th!!!
Designed, engineered and manufactured in-house at API, our new Competition Catch-Can V 2.0 improves every aspect of our best in class Competition Catch-Can V 1.
- Machined from Billet 6061-T6 Aircraft Aluminum
- Improved Filtering Process
- Collector Holds 32% More
- Quick Release Collector (37° Twist)
- Billet Aluminum -8 AN Fittings
We believe our V 2.0 to be the best-in-class, not just for the HEMI enthusiast, but for all enthusiasts regardless of brand. V 2.0 utilizes a centrifugal flow pattern to virtually eliminate oil entering your intake system. After passing through the more efficient V 2.0 Stage 1 stainless steel filter media, oil droplets the diameter of a human hair are collected and drained into the collector. In Stage 2, the blow-by gases are steered through a Green Filter crankcase filter to remove oil droplets as small as 40 microns that make up more than 50% of blow-by oil mass. API’s new V 2.0 Catch-Can is so effective we had to increase the capacity of the collector by 32%.
To empty the V 2.0 collector requires a twist of only 37°. The collector positively clicks into place through a cam-lock design with two spring loaded stainless steel balls for positive locking. -8 AN fittings allow optimal flow with the OEM PVC valve. The threads in the V 2.0 are standard AN 3/4” – 16 pitch, providing our clients with the ability to custom plumb for special applications. V 2.0 Competition Catch-Can is manufactured by Arrington Performance.
Retail Priced at $299.99
Get Yours Now for the Introductory Price $259.00
Valid Through Friday, June 27, 2014
Guaranteed to Ship No Later Than July 12, 2014
Call Today to Order Yours: 866-844-1245!
