Jack stands
Discussion in 'Dodge Challenger General Discussion' started by SFCR, Mar 9, 2017.
  1. SFCR
    SFCR Active Member Military Public Safety
    Nov 28, 2015
    1,377
    Media:
    9
    940
    Gender:
    Male
    Wilmington, NC
    Vehicle?:
    Challenger
    Model Year?:
    2016
    Trim?:
    R/T Scat Pack
    Color?:
    Plum Crazy
    Transmission?:
    8-Speed Auto
    Hello everyone!
    I am planning to do some wheel changes next week...but we'll see. I am thinking to set my Challenger on jack stands and take all 4 wheels off and put the new ones on. I'm doing it this way because I don't trust the dealership too much. Their techs are good, but some don't pay attention to detail and I don't want them scuffed or chipped. I have a low-profile floor jack, but where are the best places under the car to put the jack stands? I'm using 4 up front because of the weight and two in the rear.
    Thanks!
  2. boyohboy
    boyohboy Active Member MOTM Winner! Military
    Jul 14, 2011
    2,409
    Media:
    20
    Albums:
    1
    1,353
    Gender:
    Male
    NE Ohio
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T Classic
    Color?:
    B5 Blue
    Transmission?:
    Auto
    Upper Right corner of this page, type in the Search box "safe lifting points" and a slew of posts will direct you in safely raising your Challenger to be able to remove your wheels; though, I am not sure if it is safe to try and use all four jack stands at the same time.
    Home Theater Guy, SFCR and jklotz10 like this.
  3. BeeScat
    BeeScat Member
    Oct 13, 2016
    249
    237
    Gender:
    Male
    Aliso Viejo
    Vehicle?:
    Challenger
    Trim?:
    R/T Scat Pack Shaker
    Color?:
    Jazz Blue Pearl
    Transmission?:
    8-Speed Auto
    I like this guys youtube channel. He has a Scat as well. This oil change video shows the jacking procedures with lift and frame support marks pretty clear - at least for the front.
  4. NEPA SCAT
    NEPA SCAT Active Member MOTM Winner!
    Dec 6, 2013
    2,530
    Media:
    39
    Albums:
    2
    4,148
    Gender:
    Male
    NE Pennsylvania
    Vehicle?:
    Challenger
    Model Year?:
    2015
    Trim?:
    R/T Scat Pack
    Color?:
    B5 Blue
    Transmission?:
    8-Speed Auto
    As long as you have good quality jack stands (3 ton rating) you will only need 1 at each corner. I have put my Challengers in the air several times. I will say have 2 floor jacks is a help (1 on each side and jack up evenly). I usually get the front up, then the rear. Jack stands can be placed at the cross members, front and rear.
    Home Theater Guy, SFCR and boyohboy like this.
  5. MarcPhrey
    MarcPhrey Active Member Military Public Safety
    Sep 12, 2013
    1,672
    Media:
    31
    Albums:
    8
    1,111
    Gender:
    Male
    Baltimore, MD
    Vehicle?:
    Challenger
    Model Year?:
    2015
    Trim?:
    SRT-8
    Color?:
    Redline Red
    Transmission?:
    8-Speed Auto
    back in 2014 I did a all around brake and rotor change on my 2011 RTC I had it on 4 stands will I took my time and changed out rotors and even painted the calipers red, let them dry. total 24 hrs on the stands no problem.
  6. FlyingMonkey
    FlyingMonkey Member
    May 13, 2016
    602
    807
    Gender:
    Male
    Georgia
    Vehicle?:
    2016 SPS
    Model Year?:
    2016
    Trim?:
    Color?:
    Go Mango
    Transmission?:
    8-Speed Auto
    Here's a question...is it reasonable when rotating tires to lift one side at a time?
    For example, lift front corner so tire clears the ground, get a jack stand in there, then lift the rear corner on the same side, switch tires, lower everything, then do the same on the other side?
    Any problems with doing things this way?
    boyohboy likes this.
  7. HemiMetal
    HemiMetal Mopartial to Challengers Member Relations Photo Winner! MOTM Winner!
    Mar 22, 2013
    7,346
    Media:
    16
    Albums:
    1
    6,947
    Gender:
    Male
    San Diego, CA
    Vehicle?:
    2013 Challenger
    Trim?:
    R/T Classic
    Color?:
    Pitch Black
    Transmission?:
    Auto
    My dream solution!
  8. Diehard
    Diehard Member
    Aug 28, 2016
    619
    Media:
    2
    361
    Gender:
    Male
    North Reading, MA
    Vehicle?:
    SRT 392
    Model Year?:
    2015
    Trim?:
    SRT-8
    Color?:
    Granite Crystal
    Transmission?:
    8-Speed Auto
    No problem so long as you're simply rotating front to back and back to front on the same side. As is required for directional tires.
    If you go by the common recommendation for rear wheel drive cars and crisscross the fronts to the rear, I would use jack stands for the back OR the front of the car.(wouldn't matter)
    Remove the 2 tires that have the jack stands.
    Remove one of the tires at the opposite end using a jack and replace it with one of the tires removed from the jack stand end.
    Lower jack and do other tire at that same end.
    (This gives you the ability to crisscross or move tire straight depending on your rotation method.)
    Now you can mount appropriate tires at the jack stand end and remove stands.
    If a person doesn't want to bother positioning jack stands, they can use a spare tire(if they have one) as a temporary replacement for the first tire removed. The spare gets replaced when the last of the 4 tires get mounted.
    Home Theater Guy and boyohboy like this.
  9. Diehard
    Diehard Member
    Aug 28, 2016
    619
    Media:
    2
    361
    Gender:
    Male
    North Reading, MA
    Vehicle?:
    SRT 392
    Model Year?:
    2015
    Trim?:
    SRT-8
    Color?:
    Granite Crystal
    Transmission?:
    8-Speed Auto
    Those Quickjacks look good. I would assume they come equipped with some sort of mechanical locking device, as a safety backup to what I assume to be a pneumatic system.
  10. boyohboy
    Jul 14, 2011
    2,409
    Media:
    20
    Albums:
    1
    1,353
    Gender:
    Male
    NE Ohio
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T Classic
    Color?:
    B5 Blue
    Transmission?:
    Auto
    Once a driving season I remove my wheels to clean them front and back, get to the inner fender wells better, and get under the car to dust and look things over.
    IMG_0001.jpg IMG_0002.jpg IMG_0011.jpg IMG_0007 2.jpg IMG_0008 2.jpg IMG_0023.jpg
    Though the Pics were initially taken on the driver side of the car everything can be transferred to the passenger side as shown on the final Pic. I placed both floor jacks into position and lifted each a little at a time to keep things even until I could place the jack stands. These pics are a couple years old and were taken for another project at the time but the same principles apply for this post.
    SFCR and HemiMetal like this.
  11. Diehard
    Diehard Member
    Aug 28, 2016
    619
    Media:
    2
    361
    Gender:
    Male
    North Reading, MA
    Vehicle?:
    SRT 392
    Model Year?:
    2015
    Trim?:
    SRT-8
    Color?:
    Granite Crystal
    Transmission?:
    8-Speed Auto
    Boy...the underside of your car looks sparkly clean. makes me feel like I'm neglecting mine.
  12. boyohboy
    Jul 14, 2011
    2,409
    Media:
    20
    Albums:
    1
    1,353
    Gender:
    Male
    NE Ohio
    Vehicle?:
    Challenger
    Model Year?:
    2010
    Trim?:
    R/T Classic
    Color?:
    B5 Blue
    Transmission?:
    Auto
    Thanks. I attribute it to OCD.
    SFCR likes this.
  13. Hotrodjohn
    Hotrodjohn Member
    Feb 28, 2017
    251
    Media:
    33
    Albums:
    1
    414
    Gender:
    Male
    Wadsworth IL
    Vehicle?:
    Challenger
    Model Year?:
    2011
    Trim?:
    SRT-8
    Color?:
    Toxic Orange
    Transmission?:
    Auto
    HemiMetal likes this.
  14. Mopar joe
    Mopar joe Challenger R/T Classic Site Supporter Level 2 Photo Winner!
    Feb 20, 2015
    260
    Media:
    9
    Albums:
    1
    381
    Gender:
    Male
    Fort Lauderdale Florida
    Vehicle?:
    Challenger
    Model Year?:
    2013
    Trim?:
    R/T Classic
    Color?:
    Granite Crystal
    Transmission?:
    Auto
    Just got mine delivered today,, looks great, cannot wait for the weekend!!
  15. dean18681
    dean18681 Member Military
    Aug 8, 2014
    581
    Media:
    7
    946
    Gender:
    Male
    Collinsville, MS
    Vehicle?:
    Challenger
    Model Year?:
    2013
    Trim?:
    SXT Plus
    Color?:
    Stone White
    Transmission?:
    Auto
    That would be awesome to have a lift like that.
  16. Elijah Fox
    Elijah Fox Member
    Apr 17, 2017
    797
    Media:
    13
    715
    Gender:
    Male
    Spring Hill Florida
    Vehicle?:
    Challenger Core
    Model Year?:
    2013
    Trim?:
    SRT-8
    Color?:
    TorRed
    Transmission?:
    6-Speed
    I used to jack up my 1970 T/A for the winter for 6 months and with 3 ton stands and had no issues.Instead of using wood between the stand and the car I used a few work gloves pulled over the top of the stands.Thanks for this post I plan on doing like boyohboy did as I want to pull the wheels of clean the fender wells both sides of the tires and under the car.As I have a OCD personality too and I know I need to address with my Challenger.Oh one good thing to do put the car in gear and put something behind the rear wheels if your raising the front first.
  17. GoManGoRon
    GoManGoRon Member Military
    Jul 9, 2017
    464
    Media:
    7
    Albums:
    1
    409
    Gender:
    Male
    Goodrich, Michigan
    Vehicle?:
    Challenger
    Model Year?:
    2017
    Trim?:
    T/A 392
    Color?:
    Go Mango
    Transmission?:
    8-Speed Auto
    Where did the guy in this video get the red thing that he slide up into the rocker panel and used to jack the car up on?
  18. Bee Keeper 16
    Bee Keeper 16 Knight of the black asphalt. Site Supporter Level 2 Site Supporter Level 1 Member Relations MOTM Winner! Public Safety
    Nov 1, 2015
    7,080
    8,832
    Gender:
    Male
    Northern Colorado
    Vehicle?:
    Challenger
    Model Year?:
    2016
    Trim?:
    Color?:
    Plum Crazy
    Transmission?:
    8-Speed Auto
  19. GoManGoRon
    Jul 9, 2017
    464
    Media:
    7
    Albums:
    1
    409
    Gender:
    Male
    Goodrich, Michigan
    Vehicle?:
    Challenger
    Model Year?:
    2017
    Trim?:
    T/A 392
    Color?:
    Go Mango
    Transmission?:
    8-Speed Auto
    Thanks Bee Keeper
    I just ordered a pair. Are you a actual bee keeper, curious because my son in law owns a honey business.
    RonG
    Bee Keeper 16 likes this.
  20. Bee Keeper 16
    Nov 1, 2015
    7,080
    8,832
    Gender:
    Male
    Northern Colorado
    Vehicle?:
    Challenger
    Model Year?:
    2016
    Trim?:
    Color?:
    Plum Crazy
    Transmission?:
    8-Speed Auto
    I am not. The handle comes from my car being a Scat Pack, 2016 model and I want to keep it for a long time. The aviator is linked to me being an avid hunter and outdoorsman.
    Thanks for asking.
    dean18681, NEPA SCAT and jklotz10 like this.
Share This Page
