There is post if you search showing diagrams for jacking " Jack Points "
I'm certainly glad you copied our posts Lou - keep them handy and be careful!@Wm. Internet Rock DJ , @Rollin’ Along , and @Derecho, I captured your images for my library of Safe Jacking Points. I hope you don't mind as I reference these key things when I work around my Challenger. Thanks ! Lou.
That’s what they’re there for, glad they’ll be of use!@Wm. Internet Rock DJ , @Rollin’ Along , and @Derecho, I captured your images for my library of Safe Jacking Points. I hope you don't mind as I reference these key things when I work around my Challenger. Thanks ! Lou.
Got 2 of these myself....strangely I never thought of putting one in the car 🤣.I keep one of these in my glove box. These pinch weld pads work great.
Premium 3" Jack MagPad™
Our 3" Jack MagPad fits all vehicles with a 3 inch pinch weld opening. WORKS GREAT WITH A LIFT!! The premium magnetic jack pads are made to be used with a floor jack with a flat top and lift the car up by the pinch weld. If you have a older style or cupped floor jack we do make a adapter for...zl1addons.com
ZL1 makes lift pads that are either temporary or mounted (two Allen screws to keep the pad in place).I am adding tire stickers to my widebody scatpack and need to lift each tire up for the installation. What jack locations are recommended for front and rear?
I thought I would share this video with you so that you can be careful with using two hockey pucks. As the jack lifts, with each pump, there is a slight lateral movement that could cause the pucks to slip past each other.I follow the photo above except in the front I jack the car up where the lift is at, further in.
I use one hockey puck for the front and two hockey pucks for the rear. Been doing that for years, never an issue.
3 unrestrained connections (2 of them relatively slippery) in the load path and an uneven floor under the jack. What could possibly go wrong.I thought I would share this video with you so that you can be careful with using two hockey pucks. As the jack lifts, with each pump, there is a slight lateral movement that could cause the pucks to slip past each other.
Not to mention a car that has been lowered. How can I feel sorry. No wonder it required jimmy rigging lol. Still sucks when something like that happens. At no point did he mention he lowered the car, but talked a out the pinch weld being so high up. Carbon fiber side skirts also could be aftermarket. I could be wrong about that though.3 unrestrained connections (2 of them relatively slippery) in the load path and an uneven floor under the jack. What could possibly go wrong.![]()
You won't regret that purchase. I purchased a pair of these about 6 years ago, they are still going strong. One stayed attached to the pinch weld on a trip back from Atlanta Dragway to Greenville SC.I ordered these. Very reasonable and very high quality. Protects the pinch weld.
Amazon.com: Byenins Large Slotted Universal Magnetic Jack Pad Weld Frame Rail Adapter(Orange) for All Model Cars : Automotive
Buy Byenins Large Slotted Universal Magnetic Jack Pad Weld Frame Rail Adapter(Orange) for All Model Cars: Jack Stands - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
