1 - 3 of 3 Posts
  1. When parking on a slight incline is is better to park nose uphill or nose downhill? Oil gets to the back lifters last on startup? Would parking nose uphill be healthier for the lifters? Seems like parking nose uphill would have the oil settle more at the back of the engine?
I would say nose pointing down hill because the oil pump pickup tube is up front. But honestly don’t think there’s much you could do. I wouldn’t recommend oil additives, or thicker oil because they can screw up the vvt and mds systems.
Makes no difference. The lifters are pressure fed and receive oil in plenty of time right at engine start.
There is no concern regarding the oil pickup. If it can manage to always be in the oil under the g-forces the oil gets subjected to and with the engine running the oil level lower in the pan than it would at engine start, any road that the car can maintain enough drip to go up or down the road the engine will be oiled properly.
1 - 3 of 3 Posts
