I lost some power with the resonator delete and its KILLING me!! I feel like I've lost 100hp! Not really but I can definitely tell a difference and I don't like it at all.
And no I never tried the fuse trick I couldn't pinpoint which one it was.Did you try doing the fuse trick yet? Not sure if that will make a difference but worth a shot anyway.
If that doesn't work, then maybe you could get a custom tune to correct it? Not even sure that would solve it though.
You could always go with an aftermarket catback system like Solo, Zoomers, Corsa, Borla, etc. Those typically maintain power or add a little hp while sounding great too.
I know Blastin Bobs also makes different types of resonator deletes. They make some with glasspacks, Magnaflow mufflers built in, etc. Maybe having some additional backpressure is all you need?
Just throwing out some thoughts. I've never dealt with the issue directly myself as I still have the stock exhaust on my car.
Carl might be referencing the #2 fuse trick: Pulling the #2 fuse to reset the PCMAnd no I never tried the fuse trick I couldn't pinpoint which one it was.
There is positive + and negative- back pressure associated with many motors. This is a function which one cannot overlook when adding, or modifying an exhaust system. Try placing a dual exhaust system on a negative back pressure system, whereas the motor is factored with positive back pressure: and see what happens.I don't agree that deleting the resonaters will cause a power loss. The engineers put them on for the noise. People are always talking about back pressure and saying you need it. It's a misunderstood concept. You need exhaust velocity not back pressure and deleting the resonaterrs shouldn't hurt anything. Getting a tuner and a good dyno tune might help.
He is but I have a 2015 and the fuse box is completely different.Carl might be referencing the #2 fuse trick: Pulling the #2 fuse to reset the PCM
All I did was replace the stock muffler with borla muffler and replace stock resonator with straight pipe.When I went from the stock "H" pipe and intake to the "X" pipe and Legmaker CAI the performance jumped for me. Its as if the vehicle could now breathe easier. I still have the stock resonators and exhaust units.
For me, I love the sound of the Corsa, Stainless and Magnaflow units. And although I don't expect a large amount of performance upgrade if I were to install an "axle back system" to complete my exhaust build, I believe customers shouldn't see a negative amount of performance from the changes.
Heard of the H and X. Always thought the H was more efficient.When I went from the stock "H" pipe and intake to the "X" pipe and Legmaker CAI the performance jumped for me. Its as if the vehicle could now breathe easier. I still have the stock resonators and exhaust units.
Got any data to back any of that up, other than opinion that a reso delete loses power and TQ? Because mine was on a dyno before and after. The OP needs to be aware when you pull the #2 fuse you have to go out and drive the car hard several times to see a change. I reset the fuse before a dyno pull and lost 23HP, we had to make 5 WOT pulls to get the HP back up to where it was.You will lose torque and horsepower when you remove the resonators. The engineers at Chrysler (FCA) are mechanical engineers. Why is it that the many wish to change the performance of the Dodge Challenger. The engineers have accounted for the very last detail.
You are certainly correct in losing power. In fact if you place the motor on a dyno, it will surely print out the negative results. We always run stock.
Phil, what were your before and after numbers with the reso delete?Got any data to back any of that up, other than opinion that a reso delete loses power and TQ? Because mine was on a dyno before and after. The OP needs to be aware when you pull the #2 fuse you have to go out and drive the car hard several times to see a change. I reset the fuse before a dyno pull and lost 23HP, we had to make 5 WOT pulls to get the HP back up to where it was.
