1 - 9 of 9 Posts
I am trying to get coilovers for my challenger, my front wheels are 275/45/20 and I have about a half inch in-between the wheel and the upper control arm bolt, I'm afraid that I won't be able to lower at all. is this something I shouldn't worry about or is their something I can do to avoid it.
i had to go with 245 in the fronts to clear with lowered .. i did 275 in rear for stagger. it close.. 2" drop..
Dazed & Confused
Don't worry, that bolt won't get any closer to your tire from lowering. The only way the tire is going to get closer is if you put a larger diameter tire on since the whole spindle assembly moves as a unit. Now tires hitting the wheel wells are another issue.
1 - 9 of 9 Posts
