On a similar note, the expressway by me has a speed limit of 65, am I breaking the law if I drive 75?
Yea its better in the long runi cant afford a cat back i will keep it as is
I disagree that mid muffler delete kits are ghetto. I had a 2014 5.7 Dodge Charger and put on a Khaos Motorsports mid muffler delete kit which sounded great, had high quality components, improved performance and was very cost effective. Many reputable companies make high quality mid muffler delete kits and it’s a very appropriate option for an upgrade in sound and performance. I have nothing against cat back systems and I have used multiple Corsa, Billy Boat and other cat back systems on different cars in the past and will probably put a Magnaflow cat back system on my 2016 Challenger Scat Pack Because I like the sound.get a catback like borla etc delete is ghetto
its ghetto (to me) because it is a cheap alternative and a crude and rudimentary way of gaining a louder car, and the sound is horrible. i have a borla atak and the sound is way better than just cutting the mufflersI disagree that mid muffler delete kits are ghetto. I had a 2014 5.7 Dodge Charger and put on a Khaos Motorsports mid muffler delete kit which sounded great, had high quality components, improved performance and was very cost effective. Many reputable companies make high quality mid muffler delete kits and it’s a very appropriate option for an upgrade in sound and performance. I have nothing against cat back systems and I have used multiple Corsa, Billy Boat and other cat back systems on different cars in the past and will probably put a Magnaflow cat back system on my 2016 Challenger Scat Pack Because I like the sound.
It really depends. If you have knowledge of what you’re doing you wont lose power and flow and have a great sounding vehicle. As far as sounding horrible I have flowmaster super 10’s on mine and it sounds spectacular.
The blasting bob's are resonator deletes. If you straight pipe the suitcase muffler too, it will be LAF. I'm assuming you mean sound levels per NC law. Sure it will sound great, just very loud over 2k RPMs. I now have a Borla. Very quiet. I may actually add mufflers to my old straight pipe plus BB set up as suggested by cdahl383 when I eventually rebuild the top end.im on the fence for mid muffler delete,NC law says i need muffles on the car and cut out are not allowed i have a blasting bobs muffler delete kits with glass packs will those pass NC laws thanks.
Terry does NC have inspection stations?im on the fence for mid muffler delete,NC law says i need muffles on the car and cut out are not allowed i have a blasting bobs muffler delete kits with glass packs will those pass NC laws thanks.
yes i need annual inspection due before renewing reg they plug tester into to the opd portTerry does NC have inspection stations?
SC inspection stations have been gone for years, about the only way attention would be drawn to you without inspection stations is if you do a burnout in front of an LEO.
Unfortunately in my situation I bought my 2015 R/T used, and the previous owner had installed an Flowmaster American Thunder cat back system which eliminated the rear muffling and replace the mids with the Super 40s. At first I thought it sounded good but the interior drone was horrible, it was so bad it would rattle something inside the dash board.
I decided to butcher up my exhaust and do some testing as the Flowmaster Super 40s were chambered style and sounded raspy outside the car, and I preferred a deep rumble sound instead.
I remembered my old glass pack days so I found a set of Cherry Bombs, cut out the Super 40s and replaced them with the Cherry Bombs, they sounded really good and was just the exterior sound I wanted, and they were cheap.
That was not the end of it, as I still had interior drone, not as bad as the Flowmasters at least the dash rattling had stopped, but still bad. I went through 2 cat back systems after that looking to stop the drone, and finally installed the SOLO system, with the J pipe drone canceling and that did it.
Wishing you the best in whatever you do. Ry
Hypothetically speaking, you could go with a modular exhaust system. Mid-deletes in place ‘till smog test time comes, put mids back in for test, pass test, then mids go out and mid-deletes go back in.im on the fence for mid muffler delete,NC law says i need muffles on the car and cut out are not allowed i have a blasting bobs muffler delete kits with glass packs will those pass NC laws thanks.
And your local muffler shop will install them for a very reasonable price. Very happy with the sound on my Scat.Dynomax mini race bullet mufflers sound great and are inexpensive.
