1 - 20 of 46 Posts
Knight of the black asphalt.
This is a tutorial of how to install Mopar Hood Pins. I had to make this in two parts. Part two is called Mopar Hood Pin Install Part 2. This kit is a genuine Mopar part. I hope you find it helpful.
Tools needed: trim removal tool, 3/4 box wrench, metal file, Phillips screwdriver, 10mm socket, small flathead screwdriver, greese pencil, drill and 1 1/4 metal hole saw.
Remove trim panel this is flexible and no tools are needed.
From this,
To this
Using a trim removal tool or a small screw driver remove outer trim attachment. Only this one.
Remove the only vertical fender bolt using a 10mm socket.
Slid black pin plate under the plastic trim and above the vertical fender bolt.
Reattach plastic trim button and vertical fender bolt.
Rub greese pencil on the top of the hood pin.
Gently close hood and look for greese transfer.
Continued in part 2
Drill hole from underside of hood. Drill through the inner and outer sheet metal. Attach rubber grommet to underside of hood hole. (Grommet not shown).
Close the hood and adjust hood pin with 3/4 inch box wrench.
Without removing the tape from the escutcheon place it over the hood pin and adjust to proper height and tighten hood pin.
Drill corresponding hole in plastic trim panel and attach rubber grommet.
Feed lanyard through grill and attach to pin plate
Install plastic trim.
Perminatly attach escutcheon secure lanyard.
Enjoy!
Some side notes. When drilling the hole into the plastic trim panel, unscrew the hood pin from the hood pin plate and apply a small amount of greese to the receiving portion of the hood pin plate. Rest the plastic trim panel on top and look for greese transfer, then drill the hole.
Place some towels over the engine while drilling holes then use an air compressor to blow away shavings.
Discussion Starter #4
Great so far. Can't wait to read the sequel. Thanks for putting this information together.
It's like a cliff hanger. I was only able to post 10 images at a time. Part 2 is up.
Discussion Starter #6
Great job, fantastic write up and photos
Thank you. I wish I could have done it in one post. I don't know if that is possible.
I am enjoying the outcome.
Discussion Starter #8
Great job, I am sure many future members will find it helpful!!
Btw, I love the close up pic of your paint. What a sparkle in the plum crazy!!
Discussion Starter #10
Dodge did a nice job of adding some pearl to the paint.
Very good write up, Sir. Would love to see some more pics of the car with pins installed, but from what I can tell it looks awesome.
Looking forward to seeing you, the car, and those dang pins in June.
Discussion Starter #12
Thank you. I'am looking forward to it as well.
Discussion Starter #16
Discussion Starter #17
Looks great! Nice job. I am not sure I could overcome the anxiety of drilling holes in my hood. :eek:
I measures 3 times and brought a new hole saw. Patients and quality tools are important.
Discussion Starter #19
How could you do it , I NEARLY shed a tear . Haha each to their own ( I think ) . Very well executed and no signs of trauma , mod well done .
ps plum crazy rocks
1 - 20 of 46 Posts
