Hey guys so I'm just looking for some advice as to how people have added aftermarket subs and amps in these cars. I have a 12" alpine type r and a hifonics amp sitting around so I was planning on building a simple box just to add a little bass and fill out the sound. Wiring the power and ground is a no brainer with our rear mounted batteries, but what do you guys suggest for the remote turn-on wire and RCA's? I've seen people recommend using a line output converter (specifically http://www.crutchfield.com/p_161LC2I/AudioControl-LC2i.html?tp=61671), but which wires would I tap into for this? Rear deck speakers or could I tap into the factory sub wires? And also what would be the easiest ignition switched +12v wire to use as my turn-on? Thanks in advance
